Mizzmo
Link?
Cool beans, Jon. I hope you guys sell a bunch.The first U.S. Whispers are packed up and headed to Nor'Banks Sailing! We will be at the Annapolis Sailboat Show with the builder Rob White.
Awesome!!!! Any chance of setting up a sea trial at the Annapolis Boat Show? My (highly experienced) F18 skipper (she's cute tooThe first U.S. Whispers are packed up and headed to Nor'Banks Sailing! We will be at the Annapolis Sailboat Show with the builder Rob White.
We take apart F18's ALL THE TIME for transport as a fleet-it's much easier to load 6 F18's on a trailer taken apart, and it doesn't add too much work on each end for re-assembly.Why can't you wankers spell anything right? It's a "Whisper".
Is the designer a Solent Uni prof? If so he must be new-ish as I don't recognize the name but it seems obvious he is with all the Solent stickers on it.
The structural concept is quite interesting as it does make the boat much stiffer but not demountable (but who does that once the boat's shipped anyway?)
The 7'10" beam is a bit weird is that so the T foils will be in the trailerable width rules although I can't see driving on the roads with the foils in the boat.
So on a T-foil boat like this i assume that upwind you try to stay as low as possible so most of the vertical foil is in the water to resist leeway. Or do you try to Veal heel it? and does the weather foil add to the RM or not?
There we go again.
Just gloss over the evidence that blows you and the boat literally "out of the water" - and try to say that it is a set up issue.
I said it could be a set-up issue-and I have hundreds of hours on a Rave to back that up(and over 1000 hours on test models that work like a Rave).
This is why your unwavering and inflexible attitude grates with so many people.Horsemanure
We understand that we are in an imperfect world. There is no magic bullet and compromises are a necessary outcome. the royal "we"--run, run.
Your black and white approach that stipulates right from wrong, good from bad is just nonsense. I don't have a "black and white" approach-it's multicolored.....
Every system needs to be appraised and considered from a holistic sense. It may work in 8 knots of flat water - but 9 knots & chop might be its undoing....
What is good for lift off at 12 knots of boatspeed is probably limited to mid twenties of peak velocity. The shrill voice of inexperience talking again: a Rave takes off between 10 and 12 knots with a top speed of 30 +. A Hobie Trifoiler takes off between 12 and 15 with a top speed close to or above 40. A Moth takes off at 7-8 knots with a top speed (so far) in the mid thirties.
What is good for steady state flying on a reach is probably sub-optimal going upwind or deep downwind. Too general-doesn't apply across the board....
One trick ponies are of interest for only a short period of time and will ultimately be superseded by its two and three trick cousins....
So to claim that something is 100% successful is a 100% certain to be found out. What a silly- nearly incomprehensible- comment!
Downforce is prevented by creating a system that doesn't allow it to occur, e.g. Moths. There is no rational reason to believe that a wand/flap system must create downforce by some mechanical axiom.I definitely don't think using downforce on the Whisper is practical or desirable-but how do you prevent it with a wand system? The only way I see is that if both guys are on the wire and the thing heels even a little they'd need to depower. Otherwise there would be downforce from the windward foil IF the wand has complete freedom of movement and enough force is available to hold the flap up.
It's a response to your assertion that there is no stability issue with foilers that use downforce. How or why it happened is irrelevant, it happened, contrary to your assertion.Rave: it would be interesting to know the story behind that picture-could
Downforce is prevented by creating a system that doesn't allow it to occur, e.g. Moths. There is no rational reason to believe that a wand/flap system must create downforce by some mechanical axiom. Wrong! Any wand system, including the Moth, creates down force in order to maintain a preset flight altitude. The question is: how would you limit the amount of downforce while still allowing it to occur to maintain altitude?I definitely don't think using downforce on the Whisper is practical or desirable-but how do you prevent it with a wand system? The only way I see is that if both guys are on the wire and the thing heels even a little they'd need to depower. Otherwise there would be downforce from the windward foil IF the wand has complete freedom of movement and enough force is available to hold the flap up.
It's a response to your assertion that there is no stability issue with foilers that use downforce. How or why it happened is irrelevant, it happened, contrary to your assertion. I NEVER said that-I pointed out that in my experience with the RAVE that the windward foil never came loose or even close. Further, I said that during the time I spent with Dr. Sam it never came up in conversation. I'm convinced that for it to happen on a Rave the most likely cause is improper set-up or a failure somewhere. The Rave develops a huge amount of righting moment with the foils-enough to break the massive aluminum cross beam above 30 knots.Rave: it would be interesting to know the story behind that picture-could
You can see the ventilation drop in the following video at about 1:06 (there are many others, but that's the only one that isn't cut before the splash), flying the foil is at about 2:07. Again, cut before the inevitable crash (in comments the poster says "The pilot that went flying had a soft landing…"). It's been on YouTube since January 2007.
https://www.youtube.com/watch?v=CRTBYyNsmic
At 3:02 in you can clearly see that there was way too little tension on the bungee-the wand doesn't go forward at all when it comes clear-it's as if it's stuck in position.
There you go, asserting that systems that generate negative lift don't have issues.I pointed out that in my experience with the RAVE that the windward foil never came loose or even close. Further, I said that during the time I spent with Dr. Sam it never came up in conversation
You mean the bit where it's skimming along happily? That's clearly a cut from a different event (it appears to be a different boat) and whatever the setup is, it's not causing any issues. The maker of the video claims to be a reseller, so if they don't know how to set the thing up, who does?At 3:02 in you can clearly see that there was way too little tension on the bungee-the wand doesn't go forward at all when it comes clear-it's as if it's stuck in position.
