DougA Class cat is 75kg/ 165lb. This thing is 2 feet longer but with crossarms molded in. I'd bet its possible but seeing if this can be done in production will be interesting.
I got my info from above.There have been three published lengths for the Whisper-17.75', 19.5' and 20.3.SOLENT WHISPER SPECIFICATIONS
LOA: (incl bowsprit) 6.2m
Beam: 2.3m
Foil length: 1.0m
Max ride height: 800mm
Displacement: 80kg
Crew weight: 150kg
Mainsail: 12.9sq m
Jib: 3.2sq m
Spi: 13.5sq m
See http://uk.boats.com/reviews/boats/solent-whisper-foiling-cat-glides-southampton/
Good video....Whisper in production!! And the question about whether the foils are "allowed" to develop RM is answered. Great videofrom catsailingnews) https://www.facebook.com/video.php?v=1642595389361526
This is another of your half-ass, careless fuck-ups: you didn't even read my post with the metric conversions where it clearly states that LOA included the bowsprit*. You were right about the weight -and I suspected as much- but couldn't find anything to back that up until this morning when I went to the various dealer sites and found the all up weight I mentioned in my previous post. I've done everything possible to get the facts on this boat. Just a short while ago the Whites site was down-it hasn't been easy. You contributed absolutely nothing with your bullshit!!!!DougA Class cat is 75kg/ 165lb. This thing is 2 feet longer but with crossarms molded in. I'd bet its possible but seeing if this can be done in production will be interesting.
I don't know where you are getting your data, but it is very wrong.
But first, please don't give state rules as if they are proof of facts. The A Class minimum weight is 75kgs but all the recently built boats that I know of have come in between 78 and 82 kgs. The new foils are adding about 1.5 kgs and the boats are having to be built stronger to take the loads. A few builders have come unstuck with boats delaminating due to these extra loads.
As for the Whisper, according to the builder and their website, it is shorter than an A (by only 90mm) and is the same width. Your information is clearly wrong. I suspect you didn't bother to consider that you were using a measurement including the bowsprit which, as you will see below, isn't even included in the weight)
Next, the builder claims that the platform weight is 78kgs, without the foils. You need to add to that the weight of a mast, boom, bowsprit, kite and jib. The mast would need to be heavier than an A to take the loads of 2 people on the wire plus the kite (I know an A Class mast would fold with that load). Then you add the foils. I would be very surprised if the whole package weighed any less than 95kgs and probably closer to 100kgs.
(Source: http://whiteformula.com/WhiteFormula_UK/Whisper.html )
ita16 is pretty well spot on with his view that 80kgs all up weight would be impossible. Shows the difference between real life experience and misinterpreting things off the web.
The above info was found by NacramanUK here: http://uk.boats.com/reviews/solent-whisper-foiling-cat-glides-southampton/and used by me because the last time I checked the Whites site was down!Of all the new foilers if I was going to buy one this would be it. But I'll build the Fire Arrow instead......SOLENT WHISPER SPECIFICATIONS
Beam: 2.3m
Foil length: 1.0m
Displacement: 80kg
Crew weight: 150kg
Mainsail: 12.9sq m
Jib: 3.2sq m
Spi: 13.5sq m
Metric converted by me:
SOLENT WHISPER SPECIFICATIONS:
LOA: (incl bowsprit) 6.2m/20.34'
Beam: 2.3m/7.5'
Foil length: 1.0m/3.28'
Max ride height: 800mm/2.6'
Weight: 80kg/176lb.
Crew weight: 150kg/330lb
Upwind SA:173sq.ft.
Mainsail: 12.9sq m/138.8sq.ft
Jib: 3.2sq m/34.4 sq.ft
Spi: 13.5sq m/145 sq.ft
Thanks to Rob G above and the new facebook video, we now know for sure that the dual independent wands on the Whisper are set up to be able to create RM if that becomes necessary. And that involves downforce on the windward foil! And, as best I can tell, they've tested it by sailing the boat singlehanded......Wasn't it answered over a year ago?
http://uk.boats.com/reviews/solent-whisper-foiling-cat-glides-southampton/In fact, according to her designer, keeping both the wings submerged is the key to her stability and performance. On take-off both foils provide lift but as soon as one foil is more heavily loaded than the other, the lazy one acts as a counter force, keeping the angle of heel in check.
There must be a setting change on the windward foil for that to occur, the video hints at 7° of movement for foil angle, which is a lot when there is also a flap. It will be interesting to see it in steep waves where it's not possible to keep both main foils in the water all the time, particularly with trailing wands. It looks good in flat water, an encouraging start.
When posting statements like that, a reference is essential. Otherwise it's just troll bait.I don't know what it is made from but I believe the Whisperhull core is only 3mm thick. Apparently it is as strong as 12mm ply.
I looked at 3d-core for a project a while ago and it is certainly interesting stuff. You can get some very impressive results on pretty thin laminates. However, for true lightweight construction, the finished laminate really is too heavy.If you have some weight to play with, it seems that it will give you better results than more conventional sandwich materials. The problem is that it gains much of its strength from resin filling the voids between the honeycomb foam, joining the laminates either side of the foam, creating a fairly dense honeycomb network of "webs" between the laminates. It means that, in reality, you are using a sandwich material that is approaching something like 250kgs per cubic metre (conventional foam is around 80 and nomex 30). So, for an A Class, you simply cannot build the boat light enough using this core material. However, with the weight of the Whisper, you probably can build a very tough boat using this.Sorry, I didn't put any more because I don't know any more. I don't know whether it was stiffness, compressive strength, shear, or whatever. My reference is talking to a man who Rob White builds a lot of boats for (but not the Whisper). Maybe something like this http://www.3d-core.com/en/3d-core/3d-core-info.html??
They claim exactly the opposite. Normally, with nomex or similar honeycomb products, it is the void that causes the problem because the laminate effectively slightly sinks into the void. However, because there is foam in the "void", you keep a constant surface.It certainly looks promising. I think print through of the resin honeycomb can be an issue though.
Hi Simon,They claim exactly the opposite. Normally, with nomex or similar honeycomb products, it is the void that causes the problem because the laminate effectively slightly sinks into the void. However, because there is foam in the "void", you keep a constant surface.It certainly looks promising. I think print through of the resin honeycomb can be an issue though.
Unfortunately, the boats I am involved in push the weight situation so hard that this product wouldn't work but I wonder how it would go in high performance boats where building to weight wasn't such an issue. I hope i get the chance to see it in action soon.
