redtim
My situation
the 1gm10 came with the boat. In its past life, the PO had all the oil fall out and an alarm failure, so he bricked the old block. He found a used block, machined the head, mated the two and off she went. The problem is, now the engine burns some oil. Not a whole lot, say around a quart every 10/20 hours, but the engine only holds 1.5 quarts, so I'm doing a lot of refilling. I was sort of content to just live with it and be mindful of the oil level but yesterday I changed the oil filter for the first time after about a year, Shitty access and such, but after an accidental flush and an hour or so of running through the rpms the oil is still squeaky clean. I assumed that the oil was getting past the rings and burning, and that if that was happening, soot would be getting into the oil, turning it black fairly quickly but maybe that's not how it works?
Any thoughts? The clean oil piece is giving me some hope that maybe its an issue that wouldn't require a full rebuild? Is that just wishful thinking? Any ideas on what else might be going on here?
