Rasputin22
Rasputin22
- 14,352
- 3,891
Yamaha 9.9/15 2 stroke will run forever and probably the reason they can still be had in some markets. And as mentioned above they can be sorted out after a dunking in no time... Ask me how I know
So you are illegally dumping sewage and don't like my legal engines? What do you suggest I do with them? Are you proposing to buy them from me?With these little non-injected 2 strokes you might as well just pour the mixing oil directly into the water. If you're comfortable doing that then do it. You're announcing to the world and the other people at the dinghy dock that you care only about yourself and not the waters we sail in.
There was a news video where they ran a small two stroke in some Lake Tahoe water in a clear tank for a few seconds, it was disgusting what it did to the water. Afterwards they wouldn't let them pour the water back in to the lake! (this was before the ban).
Several years ago I got in a bit of a shit storm here for confessing that I use the bucket and chuck or direct deposit method for disposing of shit on my little head-less F242 while cruising in remote areas. I don't believe there is any comparison between the damage done by the odd turd in open water versus the oil pollution from 2 smokes- that smoke is unburned oil/fuel and goes straight into the water.
At least 20 knots please.Speed costs money, how fast do you want to go![]()
This is a fear of mine and we we don't want one over 60 or so pounds. We don't have a davit to lift it up and we don't have a fancy swim step. A halyard will do though hopefully pretty wellYamaha 9.9/15 2 stroke will run forever and probably the reason they can still be had in some markets. And as mentioned above they can be sorted out after a dunking in no time... Ask me how I know
This is why people are changing carburetors and stuff on these lower hp outboards that share blocks with higher ones no?Speed costs money, how fast do you want to go
My ancient USED engines cost over a grand each, so even used speed is not cheap.
As for the engine weight, there are usually 2 or 3 different horsepower levels per block, so you can compare weights and get the most powerful at the same weight![]()
Confirmed. I use a halyard on my 98 pound outboard and it is super easy. The engine has a lifting eye under the cover.This is a fear of mine and we we don't want one over 60 or so pounds. We don't have a davit to lift it up and we don't have a fancy swim step. A halyard will do though hopefully pretty well
Perfect! And awesome about the lifting eye I didn't even think about that. Otherwise we can devise some straps. We even have a spin halyard on a rotating block up top so we won't pull the halyard off the scheeve lifting from the beam of the boatThis is why people are changing carburetors and stuff on these lower hp outboards that share blocks with higher ones no?
I have an epropulsion on my dinghy and love it. 10 foot avon inflatable, inflatable floor (not hard bottom) with wood transom on which the motor mounts. Cruises at about 4+ knots, quiet, no gas issues, will go for over an hour at full throttle, and quite a bit longer if I throttle back to about 3/4 throttle. I've never had it run out of juice on me so I can't testify as to how far it will go.If it's not a planing dinghy, and you don't need to motor for hours on end, electric.
I've had one of those little Suzukis for about 15 years. Tried drowning it, dropping it, baking it in the sun, spooling fishing line with the prop...just can't kill it. And that sucker still starts on the first or second pull.This little guy weighs 29 pounds
Suzuki 2.5 HP DF2.5S5 Outboard Motor
Suzuki's 2.5hp model DF2.5S5 outboard motor is a perfect choice for square stern canoes, small tenders and inflatables as well as other small craft. At only 29 lbs, it's the lightest 4-stroke Suzuki outboard ever built.onlineoutboards.com
Do you think anyone has ever put a good 2-stroke engine in a dumpster? They get sold on to other people who use them instead of you.I'm sorry my friend but just like dumping used motor oil down the storm drain or in the vacant lot is no longer done by anyone of conscience, in my opinion 2 strokes are the same (not the direct injection kind...).
I try to live with myself for the odd turd in a million square miles of water. I wouldn't and couldn't in a closed harbor or cove.
What to do with them? I don't know, interesting problem.
Trolling motor- 15lbs.What I have not seen is consideration given to the idea of extra weight aboard and the main mother ship engine working harder and going slower with the burden. The cruising boat is really a system.
That's an interesting consideration actually. Like Ajax said, it's probably lighter than some batteries, but an 9.8hp 2 stroke is roughly 60lbs, a 5hp 4 strokeis roughly 60lbs, and we have 2x 200ah lithium batteries that weigh 45lbs each.What I have not seen is consideration given to the idea of extra weight aboard and the main mother ship engine working harder and going slower with the burden. The cruising boat is really a system.
