Jim Donovan
- 700
- Thread starter
- #1,021
No problem - Jim Antrim is a friend; Eva and I built most of his own boat.
I used to live in a log cabin one mile up a dirt road in Middlesex, VT. In the Spring, mud season was a "treat". I had an S10 Blazer and it would get tugged from side to side as I went up and down the road.We had two days in a row of 50ish weather which has brought on the second season in Vermont; "Mud". Careful route planning is required to avoid loosing a shoe in the muck.
No worries, the thermometer is headed south and we'll wake up to freezing rain and then a hard freeze (12 F) Saturday morning = frozen/slippery mud.
The "weather window" I've been waiting for to shift a few boats out of the shed so I can get the 20 elevated and fit the keel and rudder is not happening. But it's the middle of February and normally it'd be a blizzard outside. I washed the truck today in the "sunshine".
Well there is a concern of a built up laminate to pin the rudder to would get delaminated as it's only attaches to the outside skin layer. Even some nice carbon gudgeons I've seen are bolted in place to carry the load all the way through.My Fareast28R had a carbon fiber rudder with really thick stainless gudgeons through bolted. I couldn’t understand why all the weight would be bolted on and not laminated in with carbon instead.
Had a rudder I built literally fall off the transom of my friends boat the first 5 minutes of use.Well there is a concern of a built up laminate to pin the rudder to would get delaminated as it's only attaches to the outside skin layer. Even some nice carbon gudgeons I've seen are bolted in place to carry the load all the way through.
Lots of it this past weekend in VTSnow, I suppose. Cool boat though.
You should come down under, 32c today!We had two days in a row of 50ish weather which has brought on the second season in Vermont; "Mud". Careful route planning is required to avoid loosing a shoe in the muck.
