2022 Sydney 2 Hobart. 2h for Tatts
mccroc
425
Sydney
So I'm guessing these aren't accepted entries yet?
A little birdie told me that most of the European 2-hander boats don't meet S2H stability because they race Cat 2 in Europe?
Well according to a 2021 ORC Certificate, the SunFast 3300 has a limit of positive stability of 112.8 - seems low? Stability Index of 107.6.
But one went last year.
The Dark Knight
1,724
Brisvegas
The Sun Fast 3200 also has a similarly low SI but one raced last year also.
However, the answer is in the race stability declaration document. These boats meet the ISO 12217-2 Cat A requirement.
The advantage of owning a European production racer :)
The Dark Knight
1,724
Brisvegas
According to this doco from the RORC, ISO 12217-2 Cat A has a minimum stix of 32
The CYCA stability declaration for the 2022 SH I attached makes no mention of a higher STIX value, just that it complies with ISO 12217-2 Cat A. But this is contray to AS's rues for cat 1
the ORCV does state the 35 for cat 1, which I guess is the Melb 2 Osaka
Category 1 Races:
  • ORCI Stability Index of 115 or greater, OR
  • ISO 12217-2 Design Category A STIX minimum of 35
Category 2 races:
  • ORCi stability index of 110 or greater, OR
  • ISO 12217-2 Design Category A (which requires a minimum STIX value of 32)
Perhaps there is another doco that states the stix 35, but the declaration seems wrong if they expect a 35
duncan (the other one)
525
Siderney
You mean like, I dunno, the NoR ?
3.1 Boat
A boat shall:
(c) Comply with AS Special Regulations Part 1 for Race Category 1. The Organising Authority highlights the following AS Special Regulations: (i) A boat must satisfy the stability criteria of the AS Special Regulations Part 1 Appendix B (extracts of which are included in Appendix B of this NoR);
Appendix B:
Non-Moveable Variable Ballast Boats
A boat shall provide evidence as follows to demonstrate that it achieves not less than:
• An ORCi Stability Index of 115 for the configuration in which the boat proposes to race; or
• International Standard ISO 12217 – 2 Design Category A except that the STIX Number shall be
increased to a minimum of 35 and the angle of vanishing stability (AVS) shall be a minimum of
120 (The OA may elect to obtain technical advice as to a boat’s eligibility and the data and
documentation supplied, at the cost of the entrant concerned. This may include having
measurements redone and documentation reproduced by another Naval Architect).
• An ORCi Stability Index of 115 and a Ballast Leeward Recovery Index of minimum 0.9 for the
increased to a minimum of 35 and a Knockdown Recovery Factor of minimum 0.9 (The OA may
elect to obtain technical advice as to a boat’s eligibility and the data and documentation supplied,
at the cost of the entrant concerned. This may include having measurements redone and
Livia
1,102
Southern Ocean
3.1 Boat
A boat shall:
Appendix B:
Not too many production boats will make that.
