2022 Sydney To Hobart
The Dark Knight
2,156
Still stretches credibility as to retain endorsed status any changes to lightship vs new would have triggered a third party weighing.
Not reweighing after changing the boat certainly sounds wrong.
My point is that idiots like RandomVibes took the (probably incorrect) wording litterally as assumed that the boat was never weighed.
Reference
142
Sorry, but where’s the evidence that anyone cheated? They weighed the boat, made some optimizations to bulb & sails, and improved their rating. This is what all the TPs do, big fucking deal.
if there’s a discrepancy with the new measured weight, it’s just as likely that the old weight was slightly off.
(In any case, using incline/floatation measurements in the water, there’s always going to be a slight measurement error, probably in the +/- 50 kg range… you can only go to about 1mm accuracy.)
dchs89
113
From the owner of Crux on the SA Facebook post regarding its rating:
"Am sad to see this post here which was brought to my attention this evening. After 13 years of racing, Cruz was reweighted and remeasured in 2021 at Woolwich Dock, not by 1, but by 2 certified measurers.
While the outcome was positive for the boat's rating, the difference was 1 click, less than 6 minutes on a 4 day race, i.e. 0.1%.
I purchased Crux (ex Blondie) in 2018 becasue I knew the previous owner optimised her for IRC. Since I am new to offshore racing let alone running a campaign, buying a ready-to-race boat was the smart option for me.
It is the first time I personally went through the reweigh/remeasure process and I do not have enough experience to claim I know why the difference in measurement. My gut feeling tells me if we can reproduce boat measurements within a 0.1% rating tolerance, that sounds acceptable to me."
TUBBY
Thus tells you everything wrong about IRC now.
Just think this through thinking about the bulb weight not boat weight.
Boat weight would have been considered 3 times a day since they bought her, minimum. Everything that comes on is considered & anything that is already there is checked that it needs to be there & and can't be lightened or replaced with a lighter one.
Goodvibes
3,546
1,097
You might want to get a revaluation of that commodity. You seem to waste a lot of it on here.
Says that guy with 29,399 posts, YCMTSU!
But there is nothing surprising about the S2H shit fight, even election results are called bullshit these days.
Chucky
47
Melbourne
I thought this Tp52 was the previous Ambition from Melbourne. I believe this boat was sold based on a new keel being made by the previous owner, therefore the new owner must have had the boat re-weighed shortly after the boat was bought in 2019?
Goodvibes
3,546
1,097
SCANAS
517
Brisbane
Yeah 2011 Vintage, started life as Audi All4One / Beecon / Temptation iii
Same gen as Crush < Envy < Ichi < Shogun 5 < Audi Azzura
& Maybe Gwelo or is that a newer one now?
Frogman56
160
Sydney
Can y'all take a pill about Celestial RSHYR etc. Some actual facts might assist:
1. It is an endorsed certificate, with the new measurements (sail areas, boat weight, overhangs) by an IRC/SA measurer.
2. The boat is weighed using a certified digital load cell, probably accurate to around 0.1%
3. The various cutoff dates mean that the final numbers were submitted to RORC more than one week prior to start.
Frog
SCANAS
517
Brisbane
Yeah that’s all good.
But was hasn’t been explained is the 213kg difference between weight of material removed from bulb & the new measured weight. Did they add that back somewhere, was the original weight wrong or is the new weight wrong. Seems like a reasonable question.
& if the boat weight only changed 26kg between certs is that enough to explain the differences in LOA & overhangs in the two certificates.
Now such things are far above my head, but that is where the rumours are starting from IMO.
JonRowe
1,217
Offshore.
Wasn't part of the original quote "we had the boat weighed and we were heavier than expected" which I interpreted as the boat was heavier than old certificate weight, that so the new weight takes account that old discrepency?
Frogman56
160
Sydney
Don't have the waterplane area and 'sink' for a TP 52 in front of me, but all they appear to have done is restore the thing to the measured condition and the flotation intended by JV.
So the overhangs etc should not change much. For example, the SO will change the most and it might be around 0.01 metres per 50 kg. In any event, the rating is most affected by the boat weight via the DLR calculation.
But since they were more or less 'restoring' who really knows?
They measurers here are serious and good at what they do.
  • Like
Reactions: grs
SCANAS
517
Brisbane
Possible of course but that opens a can of worms as that means one of the measured weights which the boat was using to compete with was wrong. Possibly for a long time ….
