AnotherSailor
BIG Eb, no wind. who will manage to finish, and how?
Did I mention the BIG eb?
Same here - PacCup prep instead of drifting around in the ebb. That and despite 283+ entries, I would be scored against just one other boat and am ineligible for the overall race or season - because I added a motor to one of my cabin top winches. The SSS, which used to be inclusive, has lost its way.We've already bailed... PacCup prep continues with no breaks allowed. locking floorboards anyone? Emergency steering?
good luck. go the Pretty Penny!I will be making the start. Did a bit of work on the motor (Bob J's suggestion of using the looms over the oil pipes is clever). planning on lighten the boat up a lot rather than sail it condo style. Going with 5 sails - including the a-sail & spinnaker. will try to dive on friday afternoon depending on work. still waiting for the dakota power box to be delivered for the auto helm so i don't have to use house batteries.
Let me know how this oil pipe wrap works for you. I'm going through the same issue.I will be making the start. Did a bit of work on the motor (Bob J's suggestion of using the looms over the oil pipes is clever). planning on lighten the boat up a lot rather than sail it condo style. Going with 5 sails - including the a-sail & spinnaker. will try to dive on friday afternoon depending on work. still waiting for the dakota power box to be delivered for the auto helm so i don't have to use house batteries.
sure will. 2 hours under motor to the start will test the looms vs warm oil pipes heat. I made a reminder and added to the log book to replace the seals in the water pump as often as the impeller or at least every year with a mild descaling.Let me know how this oil pipe wrap works for you. I'm going through the same issue.
I missed the original thread, what's the loom protecting? (Sorry 3BFers, big ebb, but the breeze forecast is looking a "little" better, 5-6 rather than 2-4)Some (maybe all) split loom is heat-resistant. Just make sure you put the split on the bottom, as best you can given the bends.
I was on the third set of oil pipes on my 1GM when I tried this. Several years later it was still fine.
If I am not mistaken you have a choice: if you do not use the motor during the race you will not be excluded from the non-motorized section.I would be scored against just one other boat and am ineligible for the overall race or season - because I added a motor to one of my cabin top winches. The SSS, which used to be inclusive, has lost its way.
The oil pipe that's directly under the wimpy little raw water pump on the 1GM.I missed the original thread, what's the loom protecting? (Sorry 3BFers, big ebb, but the breeze forecast is looking a "little" better, 5-6 rather than 2-4)
True, and I did that for the last two years. But now that our ratings are subject to adjustment for the winches, the SSS needs to stop penalizing the powered-winch boats a second time by excluding them from the perpetuals, season championship and the ability to be scored against the boats we used to share divisions with. NorCal PHRF made it clear that this was not their intent when they wrote the powered-winch rule last year.If I am not mistaken you have a choice: if you do not use the motor during the race you will not be excluded from the non-motorized section.
I doubt you will need any assist on your winches this time.
Ok, I see. Well, I would take it up with them and ask them about their intent. In my (admittedly somewhat limited) experience with them it seems to me they listen to folks.True, and I did that for the last two years. But now that our ratings are subject to adjustment for the winches, the SSS needs to stop penalizing the powered-winch boats a second time by excluding them from the perpetuals, season championship and the ability to be scored against the boats we used to share divisions with. NorCal PHRF made it clear that this was not their intent when they wrote the powered-winch rule last year.
So I'm "representing" (or trying to).
Oh and if you have to anchor against the ebb, and have a larger boat with a powered windlass, pull that anchor by hand or you'll get scored separately!
You mean the SSS board? If so, I did. Their answer was vague but the gist was they think PHRF isn't doing enough. Over 20 years that I've been in the club, this is the first time the SSS board has ventured into the ratings business - something past boards said they wouldn't do.Ok, I see. Well, I would take it up with them and ask them about their intent. In my (admittedly somewhat limited) experience with them it seems to me they listen to folks.
I'm not upset - I'm content with my decision to sit out the SSS season. Yes, I could have not used the magic buttons again this year but now that NCPHRF has fixed the issue on the rating side, I'm trying to get the SSS to fix the double penalty this created. I'm representing a few older singlehanders (not just myself) and I'm not receiving understandable reasoning from the SSS board. Note I'm a singlehander - all the PW boats registered for the 3BF are doublehanders.@BobJ I understand why you're upset with SSS's policy of splitting out boats with powered winches into separate divisions, but it seems like you have some options:
- Don't put powered winches on your 2022 PHRF cert, and don't use them while racing.
- Ask SSS to combine the "Spin PHRF 108 and under" and "Spin PHRF 111 to 159" powered winch divisions, which would have given you a division of 10 boats instead of 2. If I were racing Sea Witch I'd definitely make that request, because a division with one boat is no fun.
- Don't race.
I'm not sure why you've concluded that #3 is the best option, but perhaps I'm missing something.
