- Thread starter
- #41
Got it. Thanks!Bottom line is you have to check that you have sufficient wire gauge to go from the breaker you want to switch to 50A (from the 30A currently), to the next set of breakers (for each branch circuit).
Eventually when you get the boat, if you can verify that the wire between the 30A breaker and the distribution buses that feed those smaller breakers can handle 50A vs 30A, and the bus itself is ok for 50A, then you're good to swap the breaker and install a galvanic isolator (if you don't already have one).
