Thank you for sharing this. Fun to see it at this stage. Glad you don't mind a second or third set of eyes looking it over.
A couple of things.
One commercial regulation that makes sense is to have the front sloped pilothouse windows at least 15° from vertical. Really helps with reducing reflections from the instruments at night. Also looks good.
I am not keen on painting that visor a contrasting colour. I think the visor should be there, but just not so obvious a styling feature. Some dredges paint the visor international orange. Not a fan. Your eye is drawn to the visor which is good if you want people to avoid your dredge but otherwise it stands out too much.
Important - paint the underside matt black or similar non reflective colour. Dark grey is OK too and maybe a bit more interesting. Having the overhead above the dash a dark colour is good here too.
Think about Autoprops too. Better powering performance than the flat blades of a Max Prop because the blades have twist versus the inefficient flat blades of most feathering props. Little more drag under sail but that isn't the main goal here, is it?
The rig looks very far forward but I'd trust Bob since he's done a lot more sailboats of this type than I have! (What's the lead if it's not a secret?)
Not keen on the searchlight on top of the cabin. The beam hitting the mast will blind you with the reflection. Maybe mounted inverted under the radar antenna with a sail guard to the sides? Maybe it's offset enough on the cabin top that it works for say +/- 15 deg of center without hitting the mast?
Like the sideboards for the nav lights.
Like that classic bow shape and stripe curve at the bow. We need more of them in our lives.
Do you really need side door on port side of cabin as well as stbd? I'd be so tempted to fit a L shaped lounging seat there that you can sit into the corner and put your feet up...
I think this stair/bhd might work a bit better for getting down the stairs and into the port side cabin. Just flows a little bit better, more cabin room, and easier to build and enter/exit flat door.
A couple of things.
