DA-WOODY
I won't say someone could shit a more solid piece of woodwork
butt I'll post this
Jus Postin
butt I'll post this
Jus Postin
I'm reading "sunburned country" Never knew how many things could kill you in Austrailia.Yes, Bryson is very funny and I think that is his best book. The one he did about England is also good. He needs to do something similar for sailors/cruisers, it would be a sure best seller.snort! That's funny. Ever read "A Walk In the Woods" by Bill Bryson? Funny AT stuff, pro writer, very good. Recommended.It reminds me of the Appalachian Trail through hikers who simply cannot bear the thought of missing a single blaze for fear of not being able to claim that they really hiked the whole trail. I'm not really proud of this, but I did send one all the way back down a mountian once because I merely suggested that his route up had bypassed a 1/4 mile of the AT.Come on! Read the whole thing!Thanks wombat, will do. I have to kill another 3 slow hours in a totally quiet tool crib with zero customers, but I am deathly afraid I will get sucked in and read the thread all night, and I really need the sleep after 3 17 hour days in a row, mate!
I did, and it only took 92 hours. (remember, you didn't really read the whole thing unless you got sucked into every tangent story along the way)
wombat6025 said:My cat just did a perfect impression of HR - arrived at the litter box, made all the right noises and even ran up and down the hall three times in celebration of her successful movement; but having missed the mark completely some other sod has to clean s**t from the carpet.
Most of what you say is spot on, but you do make a lot of assumptions.Examination of the brand on one of the plywood sheets shows it as having a code of 24/0, but it is also stamped NOT FOR WALLS. Other sheets have different brands.
Typical sheathing and Structural I sheathing have a two-number span rating (e.g., 24/0, 24/16,
32/16, 48/24, etc). For a two-number span rating, the number on the left identifies the span
rating (truss or rafter spacing) if the panel is used in a roof application and the number on the
right identifies the span rating (joist spacing) if the panel is used in a subfloor application. Panels
with the number zero on the right are not allowed to be used in subfloor applications.
http://www.tecotested.com/techtips/pdf/tt_gradestampps1ps2
So if the plywood is not for walls, and its not for subfloors, then its only use is trusses and roofing. Some of them are branded clearly as construction grade c-x.
It looks as though he has either bought a whole lot of miscellaneous sheets as a job lot, or collected a motley collection as leftovers from building jobs...
Why am I left with the feeling that a divorce settlement has meant that Rod had to empty out his shed .?
OOoo boy, a guy who can't figure out basic carpentry is going to have a try at electrical wiring? I wonder how many stars? This is going to be good... probably very short (pardon the pun) but good.I'm waiting for lilmurray and the romex story too. I'm curious if there's any possibility that the zinc on the carriage bolts would act as anodes for said electricity?
What's the big deal?? I have done this many times!wombat6025 said:My cat just did a perfect impression of HR - arrived at the litter box, made all the right noises and even ran up and down the hall three times in celebration of her successful movement; but having missed the mark completely some other sod has to clean s**t from the carpet.
Like HR, at least she got up and did something, and we should all celebrate that.
Speaking of celebrating questionably useful acts, my dog managed to drool all the way over the top of her own nose yesterday.
Wait ... You have fucking.chickens?Thanks wombat, will do. I have to kill another 3 slow hours in a totally quiet tool crib with zero customers, but I am deathly afraid I will get sucked in and read the thread all night, and I really need the sleep after 3 17 hour days in a row, mate!
Edit - Holy Sheepshit Batman!!! That is quite obviously the cheapest crappiest grade of lumber known to man! I wouldn't house my fucking chickens in something built with that. He would have had to coat both sides immediately with a half inch thick epoxy coating to have any hope of it not immediately coming apart. There is a fine line between genius and nutjob and it's pretty obvious which side of the line this poor bastard is. Sad really.....
thinking the same thing....lol can you imagine that messI'm waiting for lilmurray and the romex story too. I'm curious if there's any possibility that the zinc on the carriage bolts would act as anodes for said electricity?
The black is hot and that will zap you. The white is neutral and that might zap you. The green is ground and usually won't zap you unless you are having a bad day. Always test wires for zapiness with your tongue first. Then the black wire goes to the little prong side of the outlet and the white go to the big prong side. The green goes to the green screw. Stick paper clip in little prong side to make sure you got it right. So that's it for 110V. Is HR reading this?thinking the same thing....lol can you imagine that messI'm waiting for lilmurray and the romex story too. I'm curious if there's any possibility that the zinc on the carriage bolts would act as anodes for said electricity?
Not yet, but when the house sells, our downsized "empty nest" probably will....Wait ... You have fucking.chickens?Thanks wombat, will do. I have to kill another 3 slow hours in a totally quiet tool crib with zero customers, but I am deathly afraid I will get sucked in and read the thread all night, and I really need the sleep after 3 17 hour days in a row, mate!
I'm reading "sunburned country" Never knewhow many thingseverything could kill you in Austrailia.
What could possible go wrong? I mean, HR is a Master Electrician right?The black is hot and that will zap you. The white is neutral and that might zap you. The green is ground and usually won't zap you unless you are having a bad day. Always test wires for zapiness with your tongue first. Then the black wire goes to the little prong side of the outlet and the white go to the big prong side. The green goes to the green screw. Stick paper clip in little prong side to make sure you got it right. So that's it for 110V. Is HR reading this?thinking the same thing....lol can you imagine that messI'm waiting for lilmurray and the romex story too. I'm curious if there's any possibility that the zinc on the carriage bolts would act as anodes for said electricity?
We just desperately need to change the subject before Gobbles blows a gasket arguing about plywood!What could possible go wrong? I mean, HR is a Master Electrician right?The black is hot and that will zap you. The white is neutral and that might zap you. The green is ground and usually won't zap you unless you are having a bad day. Always test wires for zapiness with your tongue first. Then the black wire goes to the little prong side of the outlet and the white go to the big prong side. The green goes to the green screw. Stick paper clip in little prong side to make sure you got it right. So that's it for 110V. Is HR reading this?thinking the same thing....lol can you imagine that messI'm waiting for lilmurray and the romex story too. I'm curious if there's any possibility that the zinc on the carriage bolts would act as anodes for said electricity?
