Caca Cabeza
Is that similar to "uncle dad"?Billybackstay: I am from Appalachia and I speak banjo. Sisteraunt is you know, his aunt. Also his sister. If you guys need any further translation, just let me know.
daduncleIs that similar to "uncle dad"?Billybackstay: I am from Appalachia and I speak banjo. Sisteraunt is you know, his aunt. Also his sister. If you guys need any further translation, just let me know.
It looks like the back porch and patio cover are sagging. Having that hog parked back there ain't helping.That thing has definitely gotten more swaybacked. Maybe HR should run some tensioning cables transversly between the hulls just above the water. A handful of Home Depot eyebolts and some cable should do it.
I figure the ultimate failure mode of this thing is one of two possibilities - it turns to mush and sinks or it does the splits and the "hulls" separate from the central pod.
What say y'all.
That shot presents WAY too many possibilities for politically incorrect and otherwise socially unacceptable comments (even for here).DA-WOODY said:Clearly the new guy in the dingy is none other than
I.O. Johnson
coat - hat - door
I.O. Johnson
coat - hat - door
The kit is actually spelt Turbo encabulator and the youtube video is a wonderful description, similar in exactly how the FH actually works.... Of course, the description of the turbo encabulator is only appropriate for appropriately educated persons.turbo entabulator.jpg![]()
I'm thinking that the piece of kit on the stern that you are unable to identify could be a Turbo Entabulator, more info here:
"Heeey uncle father Oscar!" -Buster BluthIs that similar to "uncle dad"?Billybackstay: I am from Appalachia and I speak banjo. Sisteraunt is you know, his aunt. Also his sister. If you guys need any further translation, just let me know.
was just going to comment on this epic photo.DA-WOODY said:Clearly the new guy in the dingy is none other than
I.O. Johnson
coat - hat - door
It's ok, it's just shadows, look at the "outdrive"... PC doesn't applywas just going to comment on this epic photo.DA-WOODY said:Clearly the new guy in the dingy is none other than
I.O. Johnson
coat - hat - door
1. They only have 1 paddle.
2.... i can't. like above, not even on SA.
that's some funny shit.It's ok, it's just shadows, look at the "outdrive"... PC doesn't applywas just going to comment on this epic photo.DA-WOODY said:Clearly the new guy in the dingy is none other than
Wonder if he is making motor noises.
True... But lest we all forget, many of us didn't think Weed would make it back sans an AMVER... But nobody wants to look at Thor Heyerdal... Kon-Tiki... 4300 miles... 1947... Balsa construction... Same shit that made those rubber band airplanes you used to play with... Let him go and send SA's keel-less posterboy to rescue him... Entertaining for sure....This is better than Stowe in many ways. YCMTSU!!! And as someone else pointed out, the Anne really was capable of handling the sea, while this thing will fold up into bits of flotsam should it ever find it's way to the high seas......
The shrouds highlighted in yellow bear a strong resemblance to an old RDF antenna I used to have. Now all he has to do is lay in a supply of butter and he's almost to Lahaina!I hate using cliches but, well um er, that's just like a Hunter rig.Thanks to Meuritt's clear photos, we can see more of the rigging quite clearly.
There's so much top-hamper I focused solely on the main mast.
Pink: forward shrouds and headstay.
Yellow: inline shrouds (diamond stays).
Green: aft shrouds.
Blue: twin backstays.
Things get a little dicey at the lower terminals of the diamonds (at the lowers.)
With that poor angle on the bobstays, that bowsprit is going to fold the first time the rig pumps.
Still lovin' the cargo boom! It may be the most practical piece of hardware on the entire boat! Wonder if that's how they got the motorcycle on the back porch?
Is that a paddle? Looks like a shovel!that's some funny shit.It's ok, it's just shadows, look at the "outdrive"... PC doesn't applywas just going to comment on this epic photo.DA-WOODY said:Clearly the new guy in the dingy is none other than
at least he's not walking through the mud towing the "TENDER"....
