CDX is the standard construction grade plywood here and every single lumberyard and building center stocks it. It comes in various thicknesses and is really useful in many applications. It is a softwood ply which means it is made from fir, pine, hemlock etc. There's nothing wrong with it and just about every structure that has wood in it uses CDX however it is NOT generally used for boat building. It is pretty hard to dent unless you hit it with a hammer and holds up OK to rain on a job site. The X means it is rated for limited eXposure to moisture. It will not delaminate overnight if it gets wet and will be suitable for a longer period of eXposure to weather as you are building the structure. They also make an exterior verion of CDX which is more suited to long term exterior use. Hopefully HR used this. It is slightly better. OSB is now eclipsing ply because it is usually cheaper.A (sensible?) question.
If you totally encapsulate 3/8 CDX ply in West System,how hard is it to penetrate the epoxy and get to the ply? We dont' get CDX over here, it's all graded differently and uses different woods. What I think is our equivalent is all softwood,would dent if you lean on it hard and a dewy night will warp and delaminate it. Will panel flexing do it, or would for example sitting the boat on some stones do it?
Is FH totally encapsulated in West system, or is it another type of epoxy? Or is it just epoxy inside and a thin skin of polyester resin with taped joins on the outside?
