HR'FH
It don't matter anyways.
6,000 Lbs per inch immersion? I don't think so.We put on 3 tons and the water line changed one inch
250 "whole" yards ;-)When I talked to HR yesterday he said he used 250 yards of glass. Maybe there is more to the FH than just seam taping.
You're new around these here part's aren't you?Paranoia lives well on this site.
I can't remember exactly what he said but on second thought 750 sounds more like it. I wasn't taking notes. An fwiw glass is frequently sold by the running yard so if that's a 60" roll then you get about twice as much. So a yard may not be a square yad but 3' X 60".250 "whole" yards ;-)When I talked to HR yesterday he said he used 250 yards of glass. Maybe there is more to the FH than just seam taping.
Work out the numbers Crab. At 65 by 32 ? by lets call it 12, it has a cubic surface area of 6,488 sq/ft and if we go with a block coefficient of say 0.60 ( and thats being generous ) we come up with a square footage required of 3893 sq/ft , but 250 yards is only 2,250 sq/ft soooooooo what kinda coverage do you really think he got ?![]()
If it was more like 750 yards then it'd be 6750 available vs 3893 needed with a BC of 0.6, a BC of 0.75 which might be more accurate considering the inside of hulls, works out to 4866 sq/ft needed vs 6750 available, or just about one layer considering overlap, assuming he didn't railroad the stuff.
It kinda sounds like he's not sure how much he used, which is kinda frightening cause there's a specific amount of resin your supposed to use for each yard of glass, depending on what the weight of glass is. Its not like you just randomly slather that shit on and call it good.
Anyway at least there is something on there B)
...there's a specific amount of resin your supposed to use for each yard of glass, depending on what the weight of glass is. Its not like you just randomly slather that shit on and call it good.
I second that.On behalf of backyard slatherers, let me just say, "Uh oh!"
HR was specific about the yardage when I talked to him The confusion is coming from me. And he said he used 1000 gallons of epoxy. That I do remember.When I talked to HR yesterday he said he used 250 yards of glass. Maybe there is more to the FH than just seam taping.
Really? that would be 18 qty 55 gallon drums. Even the cheapest epoxy would be too cost prohibitive for HR in those amounts.HR was specific about the yardage when I talked to him The confusion is coming from me. And he said he used 1000 gallons of epoxy. That I do remember.When I talked to HR yesterday he said he used 250 yards of glass. Maybe there is more to the FH than just seam taping.
Hot Rod,We put on 3 tons and the water line changed one inch
