JulianB
- Thread starter
- #461
OK, I have worked this out.couldn't see this being queried and it came up in the Laser/5o5 thread so had a query on it.
Firstly, cool graphic, i like it and the vertical is easy to see from Portsmouth ratings.. BUT, what's with the power?
is it direct sail area?
looking at the horizontal axis in terms of power from left to right we have:
RS100<Laser4.7<Finn<Musto Skiff<Laser std<Europe<O'pen Bic
doesn't make sense to me, what am i missing?
1stly, there are no fudge factors, its super simple maths, all above board, no emperical input. No personel judgments.
It uses simple hull speed equations, and arms x weight formulas.
The size of the oval is also prorata in that say a 29er spinnaker is a bit bigger than the working sail area, where as a Cherub spinnaker is a lot bigger, so it gets a bigger oval.
Re power, if you work out available RM, then go work out SCP and then put SCP/all up weight you get the power position.
All of that has been discussed before in these (SA) pages, so suggest you go digging into that if you need more clarity.
jB
