JulianB
- Thread starter
- #681
HI, so it (the rudder) ended up weighing 4.6kgs, and it more than passed the "whale test" it's given me extra confidence in the fin as it's only 34mm thick at the lower gudgeon where as the fin is 55mm thich, I have used almost the same laminate thickness, so if 4.5mm of Basalt is in the rudder at 1200mm easily passes the Whale test, then the 55mm thick fin, with 4.5mm thickness of basalt at the keel, at 1400mm should have no issue.
Some issues with the brass pivot and crap going down the hole, but I have a 12mm OD x 700mm LOA drill coming and that should clear it out.
Moulds unfortunatly are completly F--ked". Lucky I don't think I will need a 2nd anytime soon, but I will take this for a sail and see how it goes before getting excited about modifications. I'm guessing I can chop 100mm off the bottom, but a few sails before now and then.
49ers, if you are not dilligent, you can sheer a M8 SS pin. M8 pin is good for 2700kgs.
49er rudder goes 760mm into the water and is held by just under 200mm rudders stock (LOA is 960mm)
So say at extreme loading CoE of the rudder is 400-420mm down, (nb1) so it's pulling, very hard to believe but 1 tonne.
nb1 it's below 1/2 way because the rudder at the surface would be venting or ventalating.
The 89er has a M12 Ti TC4 pin, sheer load on that is up around 5500kgs, 1200 down and 500mm up.
Hard to believe you would get 4 tonne on it and 4 tonne pulling on the back of Scallywag or Commanchee will get a lot of motion, on the back of Don't Panic it should be sending us in pirquets! .
Scary loads, can't tell you the load we put on a 49er rudder blade tip went certifying, because I will get crucified by WS but every rudder (and centerboard) is tested to that load and then another lesser load where the deflection is measured. What I can tell you is the load we put on a 49er is a lot less than the 120 + kgs I put on the 89er rudder (within 100mm of the tip) and it came up trumps, did not even move that far, maybe 100mm.
Very happy boy at the moment, it's all coming together!
jB
jB
