89er
allweather
88
baltic
BTW, yep, pulled the 2 x M5 MT out of the brass, was up under there this morning (before the heat kick in). Brass is still there, and a rip in the FRP receiving tube. Not major! GT and I will be on the case Tuesday
So, the formula approach to build as light as possible and reinforce the areas you break testing? Sure sounds like you had fun with the boat regardless and those pictures going upwind! The boat even looks fast and light on it's feet.
11,635
Technically or theoretically HS of DP is 6.15kts, so if I was worried about maximising HS, then I would have gone to some effort to make sure it was 8.5m.
But I don't think I have taken it up-wind yet at or under HS, so whether its 8, or 8.2 or 8.5m is neither here nor there. I did have Dave (Lambourne) tell me I under cooked it, but again, not sure it's anything to get hung up about. I carries 1/2 tonne crew weight well, it's seemingly viceless so at the moment, maximise width, because that is important, but hull length, not so phased!
In the photos above, she doesn't look really cranked-in close hauled, footing off a bit, but there's a noticeable stern wave. In the one from high up & astern, it's hiding most of the transom... thus showing the crest of the stern wave is well aft of the transom. I always take that as a good sign for hull form, that the water isn't clutching the hull with a strong grip and holding it back.
JulianB
2,088
Sydney mostly
I think 12 months ago took a shot with 2 champagne glasses from the same spot.
This year it's Gin & Tonics, got to keep up the traditions!
Alex and I went to some effort to bolt that block in because it's so inaccessible, not sure why it came out, could be the far finer threads on the Metric system, where as the BSW thread is coarser and possibly better suited to Brass, don't know but 2 x M5 MT should be close to 1.5 tonne especially in sheer and the brass is still there, happy as Larry, anyway, we did design the turning block to be capable of carrying 1 + tones, that should have been maybe a 3 times safety margin, we thought, shite happens, it won't happen again.
The issue with the jib was that the sheeting attitude was to vertical, so we cracked it. I was very happy with BS, and TWA, we were sailing through those boats that were around us easily and you can't do that going slow or going low, but the instrumentation we had, was tracking rather than live. The Veliciteck comes today I think, hard to find one in Australia at present, and it's GT's side of the arrangement, so next weekend, should be far more enlightened WRT BS and Tacking Angles.
Probably sailing Saturday, maybe Sunday.
jB
peterivanac
19
As promised Don't Panic measurement form,
Not sure why it's not needed but draft is 1815mm, so 160mm of Bulb (Dia), 1420mm of fin depth & the boat is 235mm in the water at the keel (at 572kgs)
Another great sail yesterday, GT over cooked the crew, so we had 7, so he opted out, we went sailing with 6, and rough calc had us at almost exactly 1/2tonne crew weight.
So we had Jack, AlexB, Jimie (Beck), Oille, Me and Jess (Jack's GF and a bloody good sailor).
I got Jess to do a lot of the steering as I darted about looking at things, we started playing with rig tensions, and made a big difference, started getting the sail looking really good, 1/2 way, Jess steering, we started doing mid to hi, 7's all the time (uphill), I grabbed the helm back, we push the nose down (Jess was squashed up between Jimie and me) and she was calling the wind really well, anyway cut a long story short, started getting into the 8's uphill, and then it stopped being 7's and constantly 8's. Interestingly, we have the capacity to step the jib out at about 10°, did not like it at all, slowed down, bring it back into 7-8° and it took off, and sat in 8's.
Also much better when confronting chop/waves, inboard it did not notice waves, Jess (who normally sails a Flying Tiger) commented & was suprised by that.
Wind was 9-12 the occasional 14, max speed was 14.5knts, we assume under spinnaker. All the issues of the (few) days before had gone, but the loads on the spin sheet are massive, possibly running to tight! The decision to go with a A3 is the right decision even if the loads are massive, we would over run a A2 all the time. Even talk about the Code Zero.
Saturday, is likely to be fresh, we have 6 again, we are now measured and Code 7 cert.
Coming together quickly. Plan is to do the drone shoot in the next 2 weeks, so you will all have a bit to look at.
Should be fun, jB
Wow only 147kg in the bulb. The 79er we sailed on the weekend apparently had 240kg? Boat did seem very "stable"
JulianB
2,088
Sydney mostly
DP's bulb is 136kgs, the fin is 11kgs making 147kgs.
Vivace's bulb was design from memory at 186kgs with about 15kg fin, so the design fin would/should have been ~ 200kgs.
I do know it has carried upwards of 350kgs bulb, no idea of the weight of the fin.
DP is amazingly stable, GT did the cockroach a few times on Saturday and those of us in the engine room (up fwd) did not even notice. Just had David (Lambourne) on the phone and we where commenting on form stability, may have got that right!
Both David and I have ordered a 70kg bulb (each) of Brain Partridge in SA, maybe I can pick them up when I'm in Port Lincoln. That will make it a tad more lively.
JulianB
2,088
Sydney mostly
Will it still self-right at 70kg? I'm assuming you've done the numbers on that!
We will pass ISO 3 which is the self righting rule, highly probably.
With 70kgs, I doubt you would self right, but even Vivace when I sailed her in 2004, with 186kgs at Belmont, we would have easily passed ISO 3, but 2 of us had to get on the level, when we capsized, to get it back up.
The plan is to do the self-righting test next week (with 136kgs), if when doing that you get the load at the tip, (you need to hold it down) then it becomes a simple sum as to how much lighter the bulb can be.
barney
15
I understand that you'd like to minimize the weight here. I wonder though, how much mast tip load would there be required when capsized at the dock, in order for her to be truly self righting in real life?
JulianB
2,088
Sydney mostly
Barney, 3 completely differing things at play here.
#1 Sails up or sails down, if your capsized, it's likely the sails are up, where as the ISO 3 is main on the boom and jib somewhere.
#2 How quickly is "it coming back up, self righting" & the 3rd
#3 did you capsize to windward or to leeward, so worst case or best case.
In Super30, my understanding is it's Cat 7, so if a Opie can sail, you can sail! No bulb required, don't even need a motor.
Port Lincoln, Cat 6???, Bay to Bay is Cat 5m, Airlie & Magie, Cat 5.
But regardless, and I am very sure that 136kgs of lead will satisfy ISO3/Cat 5 in-terms of "self-right", we have tested the "fin" to 250% which is above ISO because I am very sure, if we happen to capsize, some of the crew will be on it very fast, and we may also find one of the crew 1/2 way up the mast holding it down while we pack a spinnaker or what ever.
But I am sure a NA in our midst, will pontificate what he thinks is enough.
14berlin
85
Munich
Hi guys, the graph I promissed
Started life on the back of a napkin, (WSC, 2014) trying to explain, initially to one mother, then to a group of parents what boat they should be choosing for their kids if they wanted to progress up from Opies into the higher reaches of the HP classes. Blue is double handed, and the oval represent the effect of the spinnaker, not sure it adds to this debate. But I need to stress all the info used comes from the WS web site, all the numbers as publish either in the classes’ rules or the tech-specs, so if your going to do this re SportsBoats, you really need to have a rock solid base line for your numbers or you will be pilloried! (Base point is the 5o5)
Twisting foils.
We went down, I was going to say rabbit hole, but it’s anything but!
Nicky (my sister) used it in the 470 in the Korean Olympics, we used it extensively in 18teens, early 80's to mid 90's and onwards), 49er do it, 29er (with FRP foils) do it and we tweaked a Cookson 12 by adding 750kgs of lead turning the L bulb, into a T bulb and adding area and strength to the TE of the fin, we added 0.75knts and 5° of height and went on to win Hamilton Island race week.
OK, the maths. Let’s use a 49er, because it’s so well tested in so many countries it’s beyond reproach, you just can’t argue with the results. And if you search the strings on SA, It’s all been said before.
Basic geometry of a 49er Centreboard!
The closest thing to the sectional shape of a 49er foil in my 60+ year-old NACA book of sections. (using this because this is a worst case secnerio, new work tells us we are doing a lot better as is the emperical evidence)
And this board supports 165kgs of crew weight with their feet say 3m from the CL and the boats are ostensibly sailed flat. ½ ve that 3m (Cl -> wing tip), add another 1m to get to the crews CoG, so 2.5m. 2.5 x 165 = 412.5kgs/m torque. Go to 9erInc and get the arm, (4.378m) so
412.5kgs-m/4.378m = 94.22kgs (force??).
So that board, outlined above is generating 94kgs resistance and at a guess 99% of the time.
OK that’s a fact, a empirically derived fact, happens every day of the week/year/decade in 50+ countries in the world and you can go down to your local boat park and come up with these numbers yourself.
Empirical evidence is also telling us that this foil is operating [in a] laminar flow "state", so if you look at the above NACA graph RHS, you can see the bucket in the graph, we are operating at a CoL, at say 5 knts (speed coming out of a tack) right in the corner, if not slightly outside the bucket, and by the time you hit cruise speed of about 7kts (nb1) it has to be operating well inside the bucket.
So pick a number inside or very close to the edgy of the bucket, I’m going to pick a CoL of 0.2 (across the bottom).
OK, now go to the graph on the LHS, go up or down (or both) the LHS numbers (CoL) and land on 0.2, run that across to the line in the middle and you will end up with a “angle of incidence” we call it a Angle of Attack [AoA] of approx. 2°!
Again empirical evidence tells us that a 49er coming out of a tack at say 5 knts gets a yaw (or yawl) of 2-2 ½ ° but once it gets to 7 knts that AoA/yaw has dropped almost to 1°, and again you can go verify this on 50+ countries most days of the week.
OK, nb1, the reason 7 knts is important to me is that’s target speed of the 89er.
So if 0.3m² of area on a 49er can generate 95kgs then
89er, 500kgs of crew, 3.5m wide, ½ ve that so 1.75m + say 200mm (gunwale to CoG of crew) so 1.95m x 500kgs = 975kgs/m divide that by the arm, 6.165m so 975kgs-m/6.165m = 158.15kgs.
So 158.15 (89er) /95 (49er) = 1.66 x 0.3008 = 0.5m² is need on a 89er if it is to operate laminar and at say 1° yaw.
0.5m² / 0.45m = 1.11279m so I am being conservative and opting for 1.4m. (yes the foil tapers yad yad yad)
So in answer to your first part, I don’t think the fin is too small, in fact I believe I am being conservative, got a bit in the bank, and given this boats potential for high top end speed and that ostensibly all it RM will come from 5 “fat old barstards” on the gunwale then it’s pretty big/long!
Come back to stage 2 (twist) after you have absorbed all of that.
Sorry for digging up this old post but it's giving me a sleepless night. I tried to do the same calculations for my I14 daggerboard but couldn't get near your 1° AoA even though the boats are somewhat similar.
So, I tried to double check your numbers:
If i put 7kts, ~90kg and 0,3m² into the lift equation, the resulting CoL is far from 0.2 (more like 0.45-0.5).
This would give an AoA of ~6° and the foil would operate outside the laminar bucket. Obviously the 49er doesn't operate at 6°. Is there an error in my equation?
JulianB
2,088
Sydney mostly
I14 Berlin, great town, we did NYE there 2019-20, Alexander Plaza, what a an extraordinary experience. You guys and fireworks are made, one flat caught on fire from memory!
And always have to respect someone (as you (& I) are) that has a greater number of + reactions than posts.
The short answer is, doing theoretical maths as you have done above, is definitely NOT my strong suite. Probably why my father said, best thing I didn't do, was finish NA.
What I am good at, and what I have sort of made my thing, is going looking for empirical evidence and then using that to make a judgment about a similar project, but while doing that, use checks and balances to make sure I don't go off the rails. So the maths of comparison and estimation I am good at. With that training/familiarisation I have made decisions and very few have been wrong.
What I can do is get a NA to do the maths, I have 3 I can ask, and they also all know that a 49er dose not have a yaw of 6° - but in the interum I can make the following comments.
A I14 is 14ft, really great boat, really only sailed one seriously maybe 3 times, and, BTW, there are lots of great boats at 14ft, NS14, Tasars, GP14, etc etc. and one of my lofty ambitions was to win a POW (that aint going to happen now). But a 29er is longer than 14ft, and a 49er is almost 2.5ft longer. They are 70kgs, so 20kgs less than a 49er (similar to a 29er).
Main and jib similar! Spinnaker, I14 is bigger (but 49er has reduced spin area and gone faster)
But WRT RM, your about 1/2 the grunt, because you don't have wings.
Hull shape is dramatically different, 49er (& 29er & 89er) have long fine Freud angles, where as a I14 is has a fullish bow, which it has to to stop plunging with all that sail area, and narrow width.
You have almost an exact sequel (you can make up your mind which came first), the GP 18teen had long fine Freud angles, the current 18teens, much fuller bows. No argument as to which did the course fastest, and yes one had 17ft wings, (as opposed to 14ft) but the fastest 18teen ever where the 17ft winged boast, not the 34ft, or the 21ft or the 18ft, so that corollary dose not hold much water.
Current 18teen far easier to sail. GP 18teen where beasts! F--ky scary!!!!!!!!
Can't say that a I14 is easy to sail because I have not sailed one and I doubt it, but a 49er can be a beast, especially if you have not come from a class like a I14, 29er, 16teen, F11 etc etc.
So, my expectation is that you have not taken into account 3 things.
#1 is the end plate effect. 49er effectively seal their Fin/Hull interface, probably less than 0.2mm gap, which a I14 with a tacking foil can't do. More to the point, every 49er foil is within +/-0.25mm of another one, so you can invest a lot of time getting that joint (bottom of the center-case) right. Add to that we have had the opportunity to experiment over 10-15 years and get the feathering of the tip right. It will never be perfect, but the 49er ratio of % camber reduction and tip flex plus probably some natural washout (feathering) is pretty damm good, and that should lead to a 2nd increase in AR
#2, is that with approx double RM, an extra 2+ft of WL and very fine Freud angles, a 49er is likely to accelerate straight past 7knts effortlessly. So the reality is that 7knts is a minimum operating speed, Cruise speed is likely to be low to mid 8's and I know (because I used to personally do it, and they are so much better than me now) that peak up-hill speeds where just shy of 12. An I14, because people still opt of a tacking board, that by definition means it spends a lot of it's time at/below HS, and that aint a lot. Finally
#3 Big believe in this, thin low drag foils/hull work best with thin low drag rigs. The corollary to that is fuller foils/hulls work best with fuller rigs. On DP (and this is a SB page afterall) we are all about drag reduction, so letting the D2's go (ease) so as to flatten the lower main so as to reduce the drag where as on the FE28r or the 6Pac or the Farr30 it was all about grunt to "smash" through . If I could have last weekend, and what I will do next weekend is ensure that I can sheet the jib right, again so I can blade it off to reduce drag, rather than up the grunt. My point being in all of this is that the 49er is now so refined that they simply blow past 7 knt's without even noticing it.
But, very interesting point of yours!!! Sorry to everyone for going of topic, but my guess is that a 49er enjoys a significant increase in AR by very effective sealing of the hull/fin interface, plus the tip dose a 2ndry seal and that it blows straight past 7knts because of its fine Freud WL's and low drag rig.
And that in turn allows it to operate with a Fin that is far smaller than basic theory would suggest. And the proof of that is the fine yaw°.
What will be interesting is to ask these NA's to factor in increase AR (due to effective end-plating, at the keel that could be 180-200%, at the tip, maybe another 125-140%) and then work out what speed the boat has to go to hit the yaw angle that we empirically observe!
Very interesting bit of maths. Maybe I will reach out to Simon (FRA), he did it before with Dad, or Joaquin (ARG). Then again I have Martin here, and he sailed DP with me last WE.
Give me a week or so, I will have to convince someone to put their name to some maths, and that could well be controversial, but I believe the answer lies there.
Plus there are some really smart people reading this, who can do this stuff while they have breakfast, just for fun, so I throw it out there for anyone to have a go.
Really, thanks for the question, makes the grey matter move.
jB
Bill E Goat
410
Sydney
12 knots upwind !!!!
I think your boat is awesome but GPS spikes can give unrealistic top speeds, thats why I asked previously about the time period over which the speeds were recorded. Thats why Nick Presse's 26knots over a 10 second period would have to be one of the fastest 12's skiff speeds ever recorded, rather than a GPS spike speed
Bored Stiff
249
Copenhagen
Interesting stuff, thanks JB.
Berlin (reminds me of Money Heist, great Netflix series), your sums are right but… first of all you have ignored any lift contribution from the rudder (which is typically about 15-25% of the lift from the daggerboard) and:
secondly, I suspect JB’s numbers are slightly out. 49er polars by Simon Watin show that boat speed of a 49er is almost equal to wind speed, upwind in 8-12kt. So, 7kt boat speed is slow for a 49er and the leeway angle will be more than 1 degree. I would suggest 4 -4.5 degrees at 7kt (including rudder contribution) which would reduce to 2.5 deg at 9kt.
14berlin
85
Munich
jB
Thank you, JB! It's great how you share all your experience as it is hard to come by any real world scenarios.
This thread motivated me to start playing around with xflr5 to get a feeling on how my boat operates at different speeds. But I learned that being able to do the math is wort nothing if you don't have the empirical knowledge to estimate all the parameters.
Btw gybing centerboards in 14s are out of fashion, except for the (very successful) Holman design all top Brits went to fixed boards.
Thanks, you are correct. I didn't take the rudder into consideration and the hull probably carries a little bit of side force, too.
For me it's really fascinating how significantly crew weight, speed and board up/down change the AoA (at least theoretically). Add to that, that real foils all have a seam at the leading edge which might effect the nose radius and surface quality, I wonder if we really achieve laminar flow most of the time.
JulianB
2,088
Sydney mostly
Hi guys, Berlin, Boredstiff, got to admit I was a bit hesitate writing this bog but certainly stirs the grey matter.
Yes, rudder should takes about 10-12% of the side load. WRT the 49er, the square head and the movement of the CoE back its probably up higher than that. I would not be surprised to learn its 20%. you need to factor that in.
The other factor that has not been taken into account is that just about every good 49er crew sails the boat heeled 4-5⁰ to windward so there will be some windward suck. I have never quantified that.
Plus the section we use is totally hydromanic, there is no aerodynamic data on it, and it has been refined and refined, especially the LE.
Just a couple of points.
The Simon Watin 49er work was 2008, pre the refinement of the Carbon rig, and pre the refinement of the new Alloy foil moulds so the boat speeds now being achieved higher.
We did (Dad & I) do a range of experiments to determine yaw. Yes you can compare SOG and Heading (compass) on both tacks and average that out. That instrumention was not good enough when we did it.
Far more fun was dye down the centercase and a camera (GoPro) mounted on the rudder frame. Also fishing line down the TE of the Centrecase with a small streamer at the transom, plus the same GoPro. I have done it so often now that I can pick the change in wake, especially on a heavier less refined boat. In the GP 18teens it was approx 4" (100mm) off CL and that would suggest sub 2⁰ yaw/AoA.
49er I have not done for a while so not going to venture there but we are well inside the bucket.
And you can feel the boat (49er) going turbulent (outside the bucket) and then clean up and accelerate as it comes back laminar/inside the bucket
But a fun project for DP on a Tuesday sail.
We did have a situation early in the GP 18teen days where we sailed in water only 1.1m deep (Perth] so our solution was to make a board that went in from the bottom and had a endplate (Goodman Feilder).
That board worked exceptionally well (& we won) other than being a real pain to get in and out, so I believe effective sealing the hull/fin joint plus careful dealtailing of the tip net significant AR benefits that you have not factored in, and I believe you should.
Final points, LE joints, paint/gelcoat is harder than epoxy, (& then you have kelp cutters) but a well detailed LE, as in 1200g you should not be able to determine the difference. Then again one of the things we did to de-whomp DP was refine the LE and that inclouded common material right around the LE.
And I14 going away from tacking foils makes total sense, as performance rises, the boat lifts and yaw drag drops.
jB
