A+T ATVMU14 Vertical vs B&G WS730
You can buy the improved PCB, bearings and vane which are all interchangeable with the 213 or if you send the vertical wand to us then we will fit a whole new sensor to this. See for parts and for vertical wand options. Please see the below data sheets for more information.
  • A+T Wind Sensor Horizontal and 213 parts v2.0.pdf
  • A+T Wind Sensors Vertical v2.0.pdf
T sailor
124
Chesapeake
I saw somewhere that the a+t MHU will have an NMEA 0183 output version? Is this available and will it work with the B&G ws converter to get it into an nmea 2000??
You want to connect this directly to the H5000 processor, not via the n2k network. The solution will benefit from the improved data rate.
Reference
142
I have the B&G 213 1m vertical wand… it looks like I could just get the new a+t Vane assembly & PCB.
Or do I also need to swap the upper /lower bearings and wind cups?
Hugh Agnew
2
UK
Two points regarding above. Yes A+T do make an NMEA0183HS version so this will work with the H5000 adaptor. The data from this is undamped, unlike that from the B&G WS.
Any of the A+T parts can be swapped, they are all separately interchangeable with B&G 213 wind sensor
