17mika
I think it is mainly related with geometry of ac40 vs ac75.Question remains as to why the loadings were higher. The lateral loadings I can see as bad luck/exceptional case, but why are the longitudinal stresses 70% higher. The boat wasn't going faster. So it seems likely the deceleration was at least partially worse due to the hull shape. Which seems like a missed factor in the design
given the relative higher ratio between ride height and lenght, the nosedive of the 40 are likely tonoccur at a higher angle to waterline, so if speeds are similar, more deceleration is not surprising. it just happens i guess because if a 40 fioter ventilate the foil, the bow can point down the mine more before it hits the water than what happens with the 75
still I am surprised no big similar capsizes happened with the small boats in previous cycle though. maybe last cycle 40s were slower so capzizes were less brutal... now I guess the 40 is not that far in speed from the 75
