sailhmb
To make minimum class weight I will need to add weight. Where is the best location; bottom of the keel or center of mass?
Keelolboat put at bortom of keel. Centerboarded put wjere tom saysSorry I should have stated no actual boat, therefore no class rule weight placement restriction. This is just a "what if" question; if you had to add weight, where would you put it, center of mass or righting moment? if you need some specificity then a 200kg boat and 10kg of weight.
If its a ballasted boat then add it to the ballast, if its an unballasted boat then don't add weight unless class rules force you to, in which case as close to the centre of pitching as the rules permit.Sorry I should have stated no actual boat, therefore no class rule weight placement restriction. This is just a "what if" question; if you had to add weight, where would you put it, center of mass or righting moment? if you need some specificity then a 200kg boat and 10kg of weight.
