stief
Apologies. GA Lesson learned. Forgot about the Weedo lessonDon't spoil it, we were having fun.![]()
As they saye in FLA "yes"...................That's the airport right over the fence from Davis Island YC isn't it?
As Ricky Ricardo used to say to Lucy, "Lucy you got some 'splaining' to do"I was wondering if they let the pilot continue after landing at the wrong strip, or did someone else get that duty?
Kinda sure. I used to TDY into Tampa Int'l periodically. I have no memory of the backgrounds in the video, but it's been ages.You sure? there was a fire truck with Tampa International Airport on the side of it in the video... Knight would make more sense, since the runways are oriented more similarly to McDill... They each have a "22"
You worked the program? Cool. Wondering if maybe we ever met in the late 80s, early 90s. I was an engine test cell weenie and helped bed down the first a/c at Charleston. I remember being in the mock-up a/c in Long Beach while the first five a/c were already in production and wondering WTF. I think it was the industry's first try at concurrent engineering and it wasn't going well. Always on the verge of cancellation. Behind schedule, over budget, over weight, under range and under powered. Very gratifying to see it not only survive but become an exceptional airplane.That’s my baby! Spent 10 years on the program. Fun times.
And it’s an amazingly capable craft. They once put an Orca in the trunk and flew to a beach on an Icelandic fiord. Got the fish to the water but found a boulder with a main gear. No prob, we shipped them a new one and our RAMS team installed it on the beach. All in a days work.
Such is the life of most, if not all, military procurements. The system has fundamental flaws.Kinda sure. I used to TDY into Tampa Int'l periodically. I have no memory of the backgrounds in the video, but it's been ages.
I was part of the “50 That Saved the Program” when McD Program and AF SPO management hated each other so heartily in the early 90s. I worked mainly with company management and the SPO. But, I liked going down to the floor or over to the fuse and wing mock-ups. Kick the tires and see what my work was making possible. Got chased off of the “Hanging Garden” assembly tooling.Kinda sure. I used to TDY into Tampa Int'l periodically. I have no memory of the backgrounds in the video, but it's been ages.
I'll drink to that and add, "If it's too big, too heavy or has to go too far, put it on a C-5."I’ll tip a glass of Highland Scotch to the best damn airlifter and all of us that breathed life into her!
There is a famous expression about pilots landing at the wrong airport. Something like "the pilot had never previously landed at XX airport..... and still hasn't".
Actually, you’ll need to put it on two FREDs, the C-5’s dispatch reliability is so poor.I'll drink to that and add, "If it's too big, too heavy or has to go too far, put it on a C-5."
I love all the heavies, even the rarely praised flying sippy cups that make global reach possible.
How do they get something that ginormous to become airborne in such a short takeoff distance? Do they exploit ground effects somehow?I'll drink to that and add, "If it's too big, too heavy or has to go too far, put it on a C-5."
A huge wing are and the power to push it thru the air. A quick Google reveals it can takeoff from a 3000 foot runway with considerable fuel and cargo. Unload everything including the drinking water then wait for a 25 kn headwind and it can depart from farm fields. Certainly ground effect helps.How do they get something that ginormous to become airborne in such a short takeoff distance? Do they exploit ground effects somehow?
It was designed to carry maximum cargo on unimproved and small airfields, a job relegated to C-130s mostly. It does that well. Comparing it to a C5 which was designed to carry the highest possible payload, like some do above, is like comparing a Jeep to an Escalade.A huge wing are and the power to push it thru the air. A quick Google reveals it can takeoff from a 3000 foot runway with considerable fuel and cargo. Unload everything including the drinking water then wait for a 25 kn headwind and it can depart from farm fields. Certainly ground effect helps.
Saw a demo at an airshow. Must have been absolutely minimum weight. Appeared to roll about its own length before rotation. Nuts.
IIRC, a kind of blown flaps via the engines exhausts. Normally, flaps have gaps at the engines, not the C17A huge wing are and the power to push it thru the air.
So it's using the jet exhaust to add turbulence and lift into the ground effect?IIRC, a kind of blown flaps via the engines exhausts. Normally, flaps have gaps at the engines, not the C17
