shebeen
indeed. very exciting stuffWell this AC cycle is off to a thrilling start.
looks like Ailinghi boatzero has sailed as much as Ailinghi 5 this summer.
I hope American Magic doesn't sink, trapping Alinghi inside its "final base."
That is a beautiful thing, alinghi sailing, at least for a while, glad everyone's ok.
think you will find its the tip of the starboard foil
What is the go with the bowsprit …..
it's for mounting a goproWhat is the go with the bowsprit …..
So the AC75 went from self righting, to not self righting, to now not even stable with both arms fully down with no sails up?think you will find its the tip of the starboard foil
Trickle indeed. https://www.sailingscuttlebutt.com/2022/08/25/photos-storm-damage-in-corsica/So the AC75 went from self righting, to not self righting, to now not even stable with both arms fully down with no sails up?
What a class! Trickle down incoming!
Drama much? All types of boats can get flattened or worse under bare poles in a squall. I found myself on a Corsair under bare pole in sustained 35 knots (gusting higher) once (after reefing etc, it was still too much sail, so we ended up taking everything down. not an easy task) and even with just the profiled mast alone it was a handful.So the AC75 went from self righting, to not self righting, to now not even stable with both arms fully down with no sails up?
