Justaquickone
- 72
Rudder bearing area would be no core just solid laminate .
Watching your build come together has quite genuinely become my main reason for checking in..! Great to see it, keep up the good work!For those following the project: The last 10 days have been about installing bulkheads and stringers. Our process was to deconstruct our male mold a section at a time, vacuuming interior lamination and installing at least some of the reinforcements in that section before moving to the next. Among other things, this protected the hull from flex.
Bulkheads, transverses and stringers were vacuumed with minimal lamination before installation to achieve a compact structure...
...then typically glued in place using braces, and then each vacuumed in place with fillets and more glass plies.
We installed some of the bulkheads in an oversized form, and will trim to size as we fit the deck, ballast tanks, and other big features. The idea here is ‘margin of error’ – my favorite self-build principle! Better a piece is too big and trimmed than too small and fudged with a lot of putty. It helps ensure we fit everything as precisely as possible for strong joins and lamination welds. Also, some of the bulkheads have complex pieces, such as the mast bulkhead into which we're building diagonal composite compression beams (as opposed to a standard compression pole in the center of the cabin). By making a bit of trimming part of the installation phase, we figured that these pieces could be fit together as perfectly as possible.
Here you can see the transom into which molded rudder mechanism ‘slots’ have been installed, but which will be trimmed lower before cockpit installation.
(Alas, still tweaking the design of those rudder control/lift mechanisms… if anyone has advice...)
Thanks to all who have sent well-wishes.
All good ideas. 4mm double braid, yes. A couple times, over morning coffee, I've noodled on what the 'breakaway' strength of a cinch line should be by measuring it against, for example, max torque force on rudders, or max compression force of composite, etc. In the end, I've decided on a healthy dose of intuition!If I was doing it I would run it up on deck(or forward no leaks) to a cleat and set it up for roughly 4mm double braid (so it will break) and have a 2 or 4 to one system in there to tension it and also so it is a little bit stretchy to keep tension on the system.
Good point, Jethrow. This concern was discussed. After a decent cure time, our plan is then to 'pre-bake' the mold thoroughly -- heating it in advance and keeping it hot until such a time as the lead is poured. This involves making a sort of heat pit for the mold. Among other advantages, this technique does a lot to reduce/manage moisture in the mold. Lead builder Raoul has done dozens of bulbs this way without trouble. (My own experience is considerably less.) A well-heated mold also helps to prevent the lead from cooling too quickly, which is a good thing given the fairly large quantity of molten lead we'll be slinging around. Anyway, that's the approach...I know you already know this, but make sure the concrete is well cured before you pour.
I used the concrete mold method once and thought the concrete was dry, but when I poured in the lead the moisture in the concrete boiled and the steam it produced put big pits in the lead and splattered lead all over the place as it escaped!![]()
