All things Class40
huey 2
2,243
syd
1Alla Grande - Pirelli
IT
1.000
20 Feb 11:10
22 Feb 18:00
32 NM
609 NM
10.3 knots
253 NM
22 Feb 21:08
2d 9h 58m 11s
2d 9h 58m 11s
2IBSA
IT
1.000
20 Feb 11:10
22 Feb 18:15
33 NM
613 NM
10.2 knots
246 NM
22 Feb 21:29
2d 10h 19m 14s
2d 10h 19m 14s
3Project Rescue Ocean
FR
1.000
20 Feb 11:10
22 Feb 18:15
39 NM
613 NM
10.1 knots
243 NM
22 Feb 22:03
2d 10h 53m 33s
2d 10h 53m 33s
4Curium Life Forward
FR
1.000
20 Feb 11:10
22 Feb 18:15
43 NM
607 NM
10.1 knots
239 NM
22 Feb 22:33
2d 11h 23m 21s
2d 11h 23m 21s
5Tquila
GB
1.000
20 Feb 11:10
22 Feb 18:15
60 NM
584 NM
9.8 knots
229 NM
23 Feb 00:21
2d 13h 11m 49s
2d 13h 11m 49s
6Nestenn - Entrepreneurs Pour La Planete
FR
1.000
20 Feb 11:10
22 Feb 18:15
61 NM
582 NM
9.7 knots
239 NM
23 Feb 00:32
2d 13h 22m 47s
2d 13h 22m 47s
7EVERIAL Diatoma
FR
1.000
20 Feb 11:10
22 Feb 18:15
86 NM
566 NM
9.3 knots
221 NM
23 Feb 03:33
2d 16h 23m 50s
2d 16h 23m 50s
8Tales 2
FR
1.000
20 Feb 11:10
22 Feb 18:00
128 NM
534 NM
8.6 knots
189 NM
23 Feb 08:53
2d 21h 43m 27s
2d 21h 43m 27s
9Vicitan
FR
1.000
20 Feb 11:10
22 Feb 18:15
139 NM
509 NM
8.3 knots
198 NM
23 Feb 10:53
2d 23h 43m 58s
2d 23h 43m 58s
10Influence
IT
1.000
20 Feb 11:10
22 Feb 18:15
147 NM
517 NM
8.2 knots
182 NM
23 Feb 12:11
3d 1h 1m 8s
3d 1h 1m 8s
11BHB
FR
1.000
20 Feb 11:10
22 Feb 18:15
171 NM
487 NM
7.7 knots
172 NM
23 Feb 16:16
3d 5h 6m 15s
3d 5h 6m 15s
12Kite
US
1.000
20 Feb 11:10
22 Feb 18:15
181 NM
478 NM
7.6 knots
162 NM
23 Feb 18:10
3d 7h 0m 21s
3d 7h 0m 21s
13Velocity
US
1.000
20 Feb 11:10
22 Feb 18:15
184 NM
489 NM
7.5 knots
164 NM
23 Feb 18:47
3d 7h 37m 4s
3d 7h 37m 4s
huey 2
2,243
syd
Its great to see this fleet this year racing ..and to see this competitve duelling.
.....heres to see the final placings from now on
1IBSA
IT
1.000
20 Feb 11:10
22 Feb 23:55
2 NM
656 NM
9.8 knots
229 NM
23 Feb 00:07
2d 12h 57m 20s
2d 12h 57m 20s
2Alla Grande - Pirelli
IT
1.000
20 Feb 11:10
22 Feb 23:55
4 NM
653 NM
9.8 knots
227 NM
23 Feb 00:16
2d 13h 6m 49s
2d 13h 6m 49s
FR
1.000
20 Feb 11:10
22 Feb 23:55
5 NM
657 NM
9.7 knots
223 NM
23 Feb 00:27
2d 13h 17m 19s
2d 13h 17m 19s
FR
1.000
20 Feb 11:10
22 Feb 23:55
9 NM
654 NM
9.7 knots
223 NM
23 Feb 00:51
2d 13h 41m 29s
2d 13h 41m 29s
5Nestenn - Entrepreneurs Pour La Planete
FR
1.000
20 Feb 11:10
22 Feb 23:55
13 NM
637 NM
9.6 knots
228 NM
23 Feb 01:17
2d 14h 7m 23s
2d 14h 7m 23s
6Tquila
GB
1.000
20 Feb 11:10
22 Feb 23:55
14 NM
637 NM
9.6 knots
224 NM
23 Feb 01:19
2d 14h 9m 55s
2d 14h 9m 55s
7EVERIAL Diatoma
FR
1.000
20 Feb 11:10
22 Feb 23:45
33 NM
623 NM
9.3 knots
210 NM
23 Feb 03:16
2d 16h 6m 39s
2d 16h 6m 39s
8Tales 2
FR
1.000
20 Feb 11:10
22 Feb 23:45
65 NM
596 NM
8.8 knots
188 NM
23 Feb 07:10
2d 20h 0m 20s
2d 20h 0m 20s
9Vicitan
FR
1.000
20 Feb 11:10
22 Feb 23:55
78 NM
570 NM
8.5 knots
195 NM
23 Feb 09:06
2d 21h 56m 33s
2d 21h 56m 33s
10Influence
IT
1.000
20 Feb 11:10
22 Feb 23:55
82 NM
582 NM
8.5 knots
192 NM
23 Feb 09:38
2d 22h 28m 51s
2d 22h 28m 51s
11BHB
FR
1.000
20 Feb 11:10
22 Feb 23:45
109 NM
549 NM
8.1 knots
173 NM
23 Feb 13:16
3d 2h 6m 38s
3d 2h 6m 38s
12Kite
US
1.000
20 Feb 11:10
22 Feb 23:45
123 NM
536 NM
7.8 knots
168 NM
23 Feb 15:26
3d 4h 16m 47s
3d 4h 16m 47s
13Velocity
US
1.000
20 Feb 11:10
22 Feb 23:45
132 NM
544 NM
7.7 knots
164 NM
23 Feb 17:01
3d 5h 51m 48s
3d 5h 51m 48s
huey 2
2,243
syd
14 minutes between Alberto Bona /IBSA and Ambrogio Beccaria / Pirelli. ..The Italians are taking over Class 40..!!
20 minutes back to Axel / Project Rescue Ocean
[email protected]
734
43 south
these are killer boats, my kinda' boat. straight up, no bullshit.
'The Ocean Race' should be using scaled-up 70ft. versions.
Or at least 60' IMOCA compliant ones. They seem more robust that the canting keel foilers, and higher volume hulls would be less affected by having a crew aboard. The 40'ers proved to be in the same league as the IMOCAs in the RdR, a 60' version would have to be faster than many older generation IMOCAs - without the complexity of foils and canting Keel.
r.finn
683
I agree. I don't really care how much faster a dot is moving on a map. What's most important is that there are enough of them to put on a show. There's not much of a show happening out there right now. 75' with material limitations similar to Class 40 and you would have boats that are plenty fast enough for sponsors and likely cheaper than an IMOCA.
huey 2
2,243
syd
Achille has been having fun as well as good results
Sardinha cup with Pierre Quiroga
Trocola
87
It's to prevent spray from shrouds and caperail rail going in the water. Probably adds righting moment when heeled over. Some class 40 ,add a tarp in the area to prevent the annoying spray going on the cockpit.
please explain walls on the hull past the mid of the hull
It's actually the old paprec arkea that won route du Rhum with yoann richome. If you go to the class40 webpage /boats it shows each boat history.
holy shit its cute..., soooo bubbly..ish
like Fugu fush
Countryclub
24
seattle
Piro, the small boards at the shrouds are for spray deflection as seen on quite a few class 40's.
The larger " bulwark " style hull sides aft of the shrouds that you are referring to are essentially a raised sheer that does not affect the Righting moment when the boat is at 90 degrees for the pull down test. It also makes a very cozy spot to stack sails on the high side and may add a little aero on the low side in light to med.breeze.
RedFlag
22
Weight it's actually not an issue on class40s. There is a minimum weight and they could build them a lot lighter.
That used to be true with "pointy" bows, where you'd typically have to add 50-100kg of iron or lead at the bottom of the hull, between the keel and the companionway, to reach the minimum weight.
The added surface area and the structural reinforcement needed to withstand the increased shocks of scow bows changed it. It has become quite hard, actually, to build a reliable scow Class40 that doesn't exceed the minimum weight.
