CA member buchhla offered a Delta to me back in November. I have not yet followed up as I have had a steady stream of anchors coming my way via the mail service. When I get up to date on the anchors that I already have, I will pursue this one further - assuming the offer is still available.I have a 20KG Lewmar delta on my boat down in Seattle you would be welcome to borrow for a test... I would love to see a Rocna vs Manson test as well. We had a 20KG Rocna on our 35' boat while we cruised from Seattle to NZ and were very happy with it. I have lots of anecdotal evidence of where we had problems, though of of those cases would be hard to recreate.
Your abrupt direction change with force is a good test though as one of the times we had an issue was when we were anchored with about 4.x:1 in about 75' of water with a nice normal 10-15 kt trades predicted a unpredicted storm came though and blew 55+ for a few hours about 120 degrees different than what was predicted. So gentle direction change due to a wind shift or current is not the only use case...![]()
H,B, Pink, plastic, lubricated or vibrating - its all good.Steve, keep up the good, unbiased, work. If folks like the sarca's are sending you anchors, they must be interested in your results and how their anchors stack up.
BTW- since this is CA, I don't think anyone would hold it against you if you suddenly had a pink, plastic anchor to test. :huh:![]()
There's quite a bit of difference between the Rocna and the Spade (I have both). The Spade has a heavy lead-ballasted tip cavity, while the Rocna has no extra weight beyond the metal plate the anchor is built from. The Rocna has the roll-bar to force it into a tip-down orientation, while the Spade uses the lead ballast and geometry. These are both great anchors. I think that for a given size anchor the Spade will likely penetrate weeds better, but a reasonably-sized Rocna with its sharp tip is no slouch in that department either.The Rocna/Manson imho is just a Spade with a hoop attached to evade copyright issues and both should come with a valid seabed mining license and a hotline number for the nearest windlass doctor.
Steve,Steve,
Thanks for posting the videos in general, and specifically for the latest Fortress tests. Very good information and much appreciated.
They match what was happening in my mind's eye when I used my FX23 on my 3500lb trimaran for 5 months (120 nights at anchor in perhaps 70 anchorages) last year in BC.
Difficult to set, and not really a solid stop when it did set. In contrast to the behavior of the 25 kg Rocna on my former 22,000 lb cruising boat, with sudden bow-dipping sets. The Fortress had previously only been used for occasional kedging off sandbanks in the larger boat.
The Fortress is retired/for sale and I look forward to trying out my new 20 lb Vulcan on the tri.
Steve M, Comox
You're going to put unmatched anchors on Frankie? Oh, the humanity.Steve,Steve,
Steve M, Comox
Where are you and how much do you want for the FX-23, I would not mind upgrading my FX-16 to a larger size for my "stern" anchor (which really goes on the bow with the new Rocna on the stern.)
Kim
When cruising FRANCIS carries two Fortresses, one CQR, one Danforth and one Rocna.You're going to put unmatched anchors on Frankie? Oh, the humanity.Steve,Steve,
Steve M, Comox
Kim
PM sentSteve,Steve,
Steve M, Comox
Kim
