Antifouling paint stripper
clucas
 I got the best price on Dumond Peel Away from my local Sherwin Williams.  Same stuff minus shipping charges for 5 gal buckets.  Great stuff and much more effective than CitriStrip.
Ron Swanson
74
Los Angeles
Yeah, wear a full-on bunny suit, gloves and goggles. Oh, and shoes you don't mind destroying. Nasty shit but it will do the job.
We've tried several stripper methods & products in our yard over the years. But the effort, mess, PPE and pretty substandard job in the end made us go back to Soda Blasting. Cheaper in the long run, safer, easier and better job for sure. YMMV
That's what our local yard says. They don't strip bottoms any more. They refer you to a soda blasting contractor who comes in.
Startracker
128
Van Isl.
You're a club.  There's multiple boats.  Offer a deal for some free advertising eg "sponsored by Bob's blasting"or a tax credit(if possible).  Not sure if it's the same as for a charity.  Call a few blasters, find out their slowest time of the year, have all the boats ready to go.  Blast and be done.  The liability in volunteers and drippy goopy stick shit that can cause injury doesn't seem like fun.   Stands and tapping could all be set up for 2x boats at a time, blaster alternates back and forth, volunteers do the setup and teardown/cleanup.
Black Dog
9
I have tried everything mentioned, Soda Blasting is the way to go. BTW if there is a barrier coat the blast wont effect it.
slug zitski
1,624
worldwide
After antifoul removal it’s recommended to apply an epoxy substrate primer before antifouling
antifoul adhesion is greatly improved
Pictured is the classic antifoul adhesion problem
the black colour is epoxy barrier coat
charisma94
Fucking Legend
1,437
465
Palma de Mallorca
Picture above is a classic case of missing over coating window. If you get the timing right after epoxy application the antifoul with etch itself into the epoxy. If you miss the window and the epoxy is cured, the antifoul just sits on the epoxy as appears in the picture.
Rule of thumb, if you've applied your epoxy, in 3-4 hours you press your thumb onto the epoxy, if it (the epoxy) comes off on your finger, it's too early... If it just leaves a fingerprint, you're good to apply the antifoul.
slug zitski
1,624
worldwide
Yes indeed ,
boats are typically antifouled outside , in the spring
many chances for a “ mistake “
a classic contamination is morning  dew running  down the topsides and contaminating the bottom
