WHK
I'm helping a friend upgrade old sensors & instruments on his J/109. He is replacing 15 year old NKE instruments. The boat speed has always suffered from tack-to-tack speed accuracy and the corrections made aren't that accurate so we are moving the paddlewheel to the centerline. I did this on my own boat and it really made a difference. I plan on mounting an Airmar P217 housing (completely flush on the bottom with no mushroom) and fairing it smooth to the hull. Since we can start from scratch on the transducer, I want to be sure that the most accurate and most responsive speed insert is used. Depth accuracy is good enough for either the triducer ior stand alone, it is most accurate speed that we want.
Is there any real data available that compares accuracy and response of a Triducer with speed, depth and temperature to a stand alone speed and depth transducer? It would not be a problem to keep the original depth transducer since it works fine, although we do plan on replacing the housing with the P217 similar to the depth in order to get a smooth faired surface. Alternately, if there is no speed performance difference, the Triducer could be used. I plan on using a NMEA 2000 smart sensor so the flexibility exists for future instrument upgrades. How good is the data on the new Ultrasonic speed transducers?
P217 Housing
Airmar ST850 Smartsensor
Airmar DST800 Smartsensor
P217 Housing
