Astus 14.5
Stjenica
3
Hi everybody, what do you thing of this trimaran ? It is affordable at less than 6k EUR, i am looking to buy something affordable, light , fast and modern LOL . CE approved in category D i hope its not only for lakes. I would sail it in Croatian part of adriatic sea with calm winds and sea.
Mid
Blues Rule
stjenica translated to English. TRANSLATION. Croatian. stjenica. English. bedbug.
Hi Stjenica,
What about buying a second hand non-foiling A-class cat instead? Same beam but longer, heavier at 75kg and a real boat. You can probably find a really good one in Italy för less money. If you think the sail area is to big and you do not want to trapeze, buy a second sail and cut it down to 10sqm to use in the beginning.
MultiThom
502
Benicia, CA
Looks like a wet boat but probably fun. No shrouds. Simple toy. Price seems pretty good if all you want is something to get out and have fun with on a lake. Like most things that are designed to do multiple things (Paddle, tri, proa), it likely won't do any of them very well.
Stjenica
3
" it has a hull from Astus 16.5 and a floats from Astus 14, two old models of the range "
also you can put it on the roof of the car with tubes on !
Looks like it reaches quite fast while flying the gennaker. I’m not sure it would have much power going to windward with mainsail only.
I agree with MultiThom that it’s more of a toy than a serious sailboat, those bows would have trouble staying above water level in any sort of wind or chop.
Do you know what the all up minus crew sailing weight is, it sure looks easy to set up and transport.
Stjenica
3
Total weight: approx. 70kg (middle hull 25kg ) , floats 7kg each , 80L, max load 130kg
Stjenica
3
I got an offer from the closest official dealer , he recommended dyneema shrouds to fix the mast and jib furler 5m2 for trimaran version. It ads up 2.3K EUR to the base proa version. What do you guys think , still a toy ?
unShirley
389
Ventura
That is about 1/3 of the price of a good, used Weta. Weta is ocean capable and quite a bit more boat in the same length. But, it isn't cartopable. I, personally, would prefer a Weta. But, my bias is obvious.
skirret
I would say for a similar performer more durable and tweakable is the Hobie Adventure island. The foot propel system and plastic hulls make it easier for other uses. Out here in Hawaii I'll see these way the heck out in the water getting thrashed around so they can handle, maybe some shrouds and different sails could help. Or get the astus 16.5 or weta if you wanna feel some umph!! Windrider also come to mind..
