Wright Way
- 224
PLB / EPIRB don't show up on chart plotters, just like flareschartplotter is saying there's an MOB
Some new PLB's are equipped with AIS, or you can get something like this, which lasts for 7 years and appears to be pretty useful particularly for racingPLB / EPIRB don't show up on chart plotters, just like flares
if you saw it at a distance whilst in on your boat , wouldnt it look like a nav light?
Electronic flares flash in "random" patterns. You will not mistake it for a nav light, but maybe you will think someone is having a disco...Well yes, but so does a normal flare I suppose
Buuuut, the WA rules state that you can only use them if you also have a PLB/EPIRB on you, so if I see a nav light coming from the same place my chartplotter is saying there's an MOB, I'D start heading over there. And then the light staying on for 10 hours instead of 5 minutes becomes a whole lot more useful.
It takes you 10 hours to motor to something in visual line of sight? You need to have a diver clean your prop or anyone relying on you to rescue them needs to be pretty good at treading water.Well yes, but so does a normal flare I suppose
That's not a PLB as far as the safety regs are concerned, you need satellite 406 model, they are VHF only, they won't initiate a search and rescue operation.Some new PLB's are equipped with AIS, or you can get something like this, which lasts for 7 years and appears to be pretty useful particularly for racing
https://www.whitworths.com.au/ocean-signal-ais-dsc-personal-man-overboard-locator-device
two very different beasts.That's not a PLB as far as the safety regs are concerned, you need satellite 406 model, they are VHF only, they won't initiate a search and rescue operation.
And for that reason, many ocean racers have both. AIS first, then if the boat doesn't turn around/can't find you/you're dying, pull the PLB... We keep ours in bum bags, so that it's not attached to a pfd that you only wear at night, and so you can have it on when you go up on deck off shift to have a piss. They also happen to be good for snacksFor ocean racing, the AIS MOB device is way more useful and they should be mandatory, not PLB's for all crew.
AIS MOB good for not much when your boat sinks and there is no one else around.For ocean racing, the AIS MOB device is way more useful and they should be mandatory,notAND PLB's for all crew.
That's when the crack that's also in said bum bag gets broken out.AIS MOB good for not much when your boat sinks and there is no one else around.
I agree both is best, but if they are going to mandate only 1, AIS is better. It does depend on the race though.AIS MOB good for not much when your boat sinks and there is no one else around.
It all depends on your circumstances, PLB for safety Regs makes sense, it always works. AIS in race sailing instructions.
If you sail in crowded waters AIS is probably better, assuming people have their AIS radio on. AIS is best for MOB.
If you need outside assistance PLB all the way.
The Bavaria 47 "Essence" sank off NZ in a gale in 2019. A wave broke over her and literally squished the hull and popped the glued windows out. The liferaft, dinghy and ships epirb also went west along with the windows. They got off the boat into the water as she went down after about 15 mins.a 406 epirb/plb is for finding the body
an ais/vhf is for finding your crew that fell over the side and you can test it...
Yes if the version epirb you have is a gps one that sends the position, much saferThe Bavaria 47 "Essence" sank off NZ in a gale in 2019. A wave broke over her and literally squished the hull and popped the glued windows out. The liferaft, dinghy and ships epirb also went west along with the windows. They got off the boat into the water as she went down after about 15 mins.
One of the crew had a personal Epirb attached to his life jacket and it saved most of them after treading water a few hours, one died 3 survived. They were located by a NZ airforce Orion and dropped a liferaft. So close to a total loss with all hands.
You can get the lat-lon of the epirb from the rescue coordinators pretty quickly.
That's changed a lot over the decade or two, there are now geostationary receivers that cover close to 90% of the planet. Satellite Response is now practically instant outside of the polar regions...................Satellite gets a 15minute window over you every 100 minutes plus you need to ensure the shore based number they will call to check the epirb owner will answer.
A geo stationary satellite is only going to work for a gps enhanced epirb as below...That's changed a lot over the decade or two, there are now geostationary receivers that cover close to 90% of the planet. Satellite Response is now practically instant outside of the polar regions.
Crew should be briefed to only activate their personal epirb when its clear visual contact has been lost.
An emergency call center will respond with the beacon LatLon as well as working with you until rescue is accomplished. Even if it's an unregistered beacon.
Then not only the calling vessel but other craft and aircraft will be coordinated externally regardless.
Consider a dissmasted vessel with crew overboard or even an inverted vessel; keel-less mono or inverted multi.
