ResilienceSailingInc
What positive experiences have people had with autopilots ocean racing and what do people recommend. Likely for an 1D35.
Tiller won't work, I agree. We must have reliability and I have been advised best way is below deck, looking at a Hobrt short handed and then a trip across the Tasman in the Sydney to Auckland raceWhile light and only 35' cockpit layout probably precludes having a Tiller AP for all but deliveries, but going to be more expensive with a below deck drive. If already have B&G you might as well follow suit using their Course Computer (that uses TWA or AWA) and also enjoy MFD AP control down below if you have one. Only choice left then is either electric or hydraulic drive where existing power generation/storage setup might help dictate that choice.
Are all the remotes as bad as the Ray S100 that takes 2 minutes to turn on every time you want to use it?Shorthanded then a pocket remote is worth its weight in gold.
Not sure, have not bought this yet, doing so shortly. All other advice I have had is under deckIs the rudder shaft exposed below deck? i.e. stuffing box / seal at lower bearing, not an enclosed rudder tube coming up to deck.
Fancy dropping the rudder to cut a keyway in the shaft for a tiller arm (I'm not sure I'd trust a clamp-on quadrant without a keyway)?
If a carbon shaft you could bond on a tiller arm a lot more easily.
Would be unusual if shaft wasn't exposed. Most solutions done to keep raceboats watertight in case of rudder failure/dropping it to avoid tearing bottom out etc are not OEM.Is the rudder shaft exposed below deck? i.e. stuffing box / seal at lower bearing, not an enclosed rudder tube coming up to deck.
