El Borracho
Verified User
My opinion on that is: The resistance imposed by a well maintained Type 1 drive is so low as to be unnoticeable. However there is a discernible inertia effect. It indeed moves without much friction, but your motion must spin the shaft, pulleys, and clutch mechanism. I think most drivers would opt to disconnect the actuator from the rudder arm when racing. A trivial operation if the area is accessible.with the Ray marine system using a type 1 linear drive, what is the standby resistance on the tiller like? is it noticeable at all? my rudder post is exposed below - trying to decide whether to go type 1 or sort a tiller pilot arrangement. but i have no feel for how much resistance the type 1 will give when not being used
The inertia effect is present with all wheel systems. Especially if the wheel is s/s rather than carbon. The weight of the wheel must be accelerated regardless of frictional resistance. That requires work.
