Because when you grab one of the sheets on a side, the other one on that side flogs you without mercy.Why? Because Ranger did so well??
Unless you are really rich.The use of stored energy for trimming sails or propulsion.
Which is stunningly stupid.There will always be things banned in some classes that are allowed in others… trapezes, hiking straps, keel trim tabs, membrane sails, movable ballast, carbon spars, autopilots, slack lifelines, faired bottoms, articulating bow sprits, outriggers, lifting foils, more than one hull, etc etc… hey, these golden globe types even banned breathable foulies!
Hey, if you want the full retro misery ya gotta get clammy!Which is stunningly stupid.
Dimples are a non-starter - unless your sub is shaped like a bathysphere.Sailboats harness a great deal of force from the wind, vs. the output of one (or multiple) man power units. So the power to drag ratio for the solution must be considered when streamlining for very low-powered applications. (The aerodynamics of a Porsche 917 Long Tail or Ferrari P4 vs. a 200 MPG closed track record vehicle are very different).
I would think that shape, surface efficiency and propulsion ideas could be best gleaned from the animal world. A fish has to propel himself with only one fish power.
The shape and the surface texture of a seal or an otter might be a place to start. They are a relatively space efficient, round but streamlined physical packages that can achieve high through-water hydrodynamic efficiencies.
The boundary layer interface of the surface of the vessel itself would offer efficiencies. Dimples on the skin surface might be interesting to test (think golf ball). Easier to align than riblets.
If you are using rotary propulsion, I would think the biggest efficiency gains could be found on how you duct fluid to the fan (propeller) and then re-introduce it back into the laminar flow with minimum upset.
Just some random thoughts at the bar...yes, I'll have another beer please.
200 mpg? PATHETIC.Sailboats harness a great deal of force from the wind, vs. the output of one (or multiple) man power units. So the power to drag ratio for the solution must be considered when streamlining for very low-powered applications. (The aerodynamics of a Porsche 917 Long Tail or Ferrari P4 vs. a 200 MPG closed track record vehicle are very different).
The record in the late 70s was 1600 MPG!
No hull or prop size or blade restrictions. Size is somewhat limited but the boy already already has his basic dimensions. Wet sub. Yes you need it to be the same sub as you started with. There seems to be an indication in the rules that bubbles to decrease skin friction are allowed, but you can’t use the air discharge for propulsion. Do bubbles work at that slow a speed?The hula wasn't banned but was a clever idea to get a different hull shape than the AC rule allowed. Got any hull shape restriction?
https://www.sail-world.com/Australia/Team-New-Zealand-reveals-total-commitment-to-the-Hula/-8282?source=google
Any prop diameter restrictions? Numbers of blades? (I would think a large slow turning 2 blade is optimimum for a Human powered sub but maybe depth/draft limits in area of operation).
Is the sub a wet sub? With a dry sub I would think to use fins for lift instead of all the lift forces coming from the submerged shape buoyancy. (i.e. it sinks if you stop pedalling. Probably a safe rule would prohibit sinkers but can you ditch a n extra flotation volume once you get moving. Do you have to finish the race with the exact same sub you started with?
Well around here the PHRF and most races now allow powered winches with barely a hit. And no further hit for racing shorthanded where the powered winches pay a multi-x advantage.Unless you are really rich.
