Autonomous
Turgid Member
A structural fillet couldn't hurt. The JSD will introduce dynamic loads the designer and builder never anticipated.
Yeah totally agree.If one did want to allow for that, reinforcement would need to run across the transom a bit, not just filling in the corner.
I'll explore that. It would be easier to do now, as the boat is 'high and dry'......The backstay chainplate bolts will be quite close to the edge of the corner fillet, so to add lams to the corner will require removing bolts to allow the layer to extend out onto the transom far enuff to add strength.
just a thought - did you give any consideration to building essentially aft facing composite chainplates. Composite chainplates are typical and normal today on race boats (it is also common to have composite emergency rudder gudgeons). You are talking about enough composite work already beefing the area up, why not just do it 'the modern way'?I'm planning to fit titanium pad eyes......
