code zero1. Any general tips for making these go?
In 10-12 kts TWS this works, will beat J109s easily on speed and pointing, outside of that window they're a dog.code zero
use it early & often
the boats have good legs for long runs and perform best when you can get a spinnaker up.
some of the guys in northern Europe have put jib tracks inboard of the shrouds which is contrary to the conventional or accepted wisdom that the boats like to be sailed fatter, but this may also be due to their use of a different rating system which does not mandate the largest sail plan possible (what we call “optimized” ß?)
have you asked this question on the 10 R Facebook page?
You can't be serious! Or did you mean 12-15 m/s? Certainly no-one around here would reef a First 10R/34.7 below 20 knots while racing. The Estonian First 34.7 fleet is probably the best in the world and I don't think I have ever seen them reef below ~25 knots.12-15 knots is when we consider reefing to keep boat on her feet.
I think the Estonian guys are running a 105% jib and madohe was referring to a 155%, but even so we now keep a 140 (IRC rule sail) up to about 20 and yes the 105% is good to about 25.You can't be serious! Or did you mean 12-15 m/s? Certainly no-one around here would reef a First 10R/34.7 below 20 knots while racing. The Estonian First 34.7 fleet is probably the best in the world and I don't think I have ever seen them reef below ~25 knots.
He said he changes to 105 in 10-12 knots, which sounds good, but to reef at 12-15 knots would certainly make you slow. Also it is likely a bad idea to reef and keep an overlapping headsail.I think the Estonian guys are running a 105% jib and madohe was referring to a 155%, but even so we now keep a 140 (IRC rule sail) up to about 20 and yes the 105% is good to about 25.
On a related note we got a 155 and the sailmaker said the sail fabric was meant for and good up to about 12 but we flew it a bunch in 16-18
Huh! Will have to try that to see, despite the ignominy of being seen with a reefed main in 16.Was told by my sailmaker that the HK fleet all reef in 16kts TWS. Boat is faster that way.
We have non overlap so don't.
That said, the boat is fully powered up in 12-14kts TWS in a flattish sea with the new fancy carbon sails. Main is doing SFA in 18kts, might look at rigging the reef.
What does "Main is doing SFA" mean? Sure the boat is fully powered up in 12-14 kts, if not even earlier. That doesn't mean reefing is needed.There are many classes that power up way sooner than 34.7/10R and never reef.Was told by my sailmaker that the HK fleet all reef in 16kts TWS. Boat is faster that way.
Don't know what rudder they have, we have the new (bigger) one.Huh! Will have to try that to see, despite the ignominy of being seen with a reefed main in 16.
Is it the case that the HK boats have the original rudder and the reefing is done to control the amount of windchecking?
Doing SFA means it's not driving most of the time. The reasoning is it's faster because powering up the main causes more heel and therefore more weather helm which needs more rudder to correct it. Full main with 50% helm is not fast. Feathering is the only other fast option but that needs 200% concentration and means the driver cannot also be skipper / tactician because as soon as you look around and lose the feather slot, the boat will overpower and spin.What does "Main is doing SFA" mean? Sure the boat is fully powered up in 12-14 kts, if not even earlier. That doesn't mean reefing is needed.There are many classes that power up way sooner than 34.7/10R and never reef.
You need to trim the headsail and rig so that you can sail up to 25 kts without excessive backwinding of mainsail. My own boat is not 34.7/10R, but is about the same size and with clearly more sail area. We used to be in trouble at 18+kts, but changed the rig trim and now we would never reef in a race below 25 kts and we are much faster than we used be. I have raced many times against the Estonian 34.7 fleet and they don't have any problems with full mainsail in 20-25 kts TWS.
I'm just watching this conversation because I have a B 40.7 with somewhat similar sailing traits. That doesn't qualify me to advise you but I think you heard from several B 10R sailors that backwinding the main shouldn't be necessary in 20-25kts apparent with a #3 up if the rig and trim are properly set. Back in the old IOR ribbon main days when the 155 genoa was the big power provider, that technique actually made some sense but I know, in my particular case, what worked then doesn't equate to fast trim on present my boat. You might want to listen to these guys. After all, you did ask.Doing SFA means it's not driving most of the time. The reasoning is it's faster because powering up the main causes more heel and therefore more weather helm which needs more rudder to correct it. Full main with 50% helm is not fast. Feathering is the only other fast option but that needs 200% concentration and means the driver cannot also be skipper / tactician because as soon as you look around and lose the feather slot, the boat will overpower and spin.
I'm listening, most definitely. I'm not saying what I'm doing is best, just trying to make sense of it all really.I'm just watching this conversation because I have a B 40.7 with somewhat similar sailing traits. That doesn't qualify me to advise you but I think you heard from several B 10R sailors that backwinding the main shouldn't be necessary in 20-25kts apparent with a #3 up if the rig and trim are properly set. Back in the old IOR ribbon main days when the 155 genoa was the big power provider, that technique actually made some sense but I know, in my particular case, what worked then doesn't equate to fast trim on present my boat. You might want to listen to these guys. After all, you did ask.
yes, backstay is enormously important. When i had an older, blown out main i was struggling in 15. new main and crushing the backstay makes the boat very controllable. I agree that trying to beat a 109 boat for boat probably wont happen unless it's really light and even then unlikely. should be quicker than a 105 but not the 109.You don't want to have too much heel nor too much weather helm, but at the same time you don't want to have excessive backwinding on the mainsail. Thus you must flatten and twist the mainsail by pulling the backstay really hard (and possibly changing the rig trim) and playing with traveller and main sheet. Backwinding is caused by headsail. It is very important to have the headsail also enough flat, twisted and not too tightly sheeted. Move the headsail car backwards (and ease the sheet) until you no longer get too much backwinding.
Target AWA increases rapidly when the wind increases above 16-20 kts. You should increase sheating angles with increasing wind and AWA.
You should not be able to match a First 35 on a beat. They are not sailing that well if you do. 16-20 kts beat First 35 should be about equal to J/109. J/109 is not that common around here, but we have a few First 35 and some of them are very well sailed. They can easily beat the Estonian 34.7 fleet in sailed times.
