You have learned an old rule, usually learned the hard way;In this case, I saved $100,000 and I think I am just as happy as I would have been with the more expensive, complicated choices.
Nice choice and am sure you will be happy with the boat. Enjoyed mine (screen name was boats name when I bought/owned it) for 7 years before moving on to the J35. Active class association with lots of support/advice from owners either here on SA or elsewhere. Time for you to go sailing!As I ran into a few disappointing surveys and sea trials I reviewed all the advice and opinions given and looked further into the S2 7.9. I found a nice one in Green Bay at a reasonable price (the upgrades alone since 2016 were equal to the selling price) and it is now sitting securely in the slip I had prepaid at the beginning of the season.
While immensely smaller than my first choices, this boat is adequate in all ways for my stated mission since I don't mind camping. It is large enough to justify keeping in a slip and small enough to trailer cross country if needed. It won't cost $5000 to store for the winter in heated storage and is pretty much maximally depreciated. There isn't much teak to maintain. It's fast and has a great cockpit. It has almost new racing sails and every option I might need or want. There are no projects that need attending to. Now I can just get back into sailing instead of boatbuilding and enjoy the summer.
That boat looks nice. I think you will have a lot of funAs I ran into a few disappointing surveys and sea trials I reviewed all the advice and opinions given and looked further into the S2 7.9. I found a nice one in Green Bay at a reasonable price (the upgrades alone since 2016 were equal to the selling price) and it is now sitting securely in the slip I had prepaid at the beginning of the season.
Not quite true. Many Hinckley B40's have participated in the Newport-Bermuda race over the years (they have a well deserved exemption to the SI rules). Most recently, "Actaea" won the St. David's Lighthouse division in 2014.Because of the shoal draft configuration, it has a relatively low ORR stability index--typically around 105 to 110 at most.
Ironically, despite its storied history, that makes it ineligible to do the Newport-Bermuda Race, which sets a minimum SI of 115.
The Bermuda 40s that participate in the Newport Bermuda Race meet the stability index requirements of 115. Many Bermuda 40s do not.Not quite true. Many Hinckley B40's have participated in the Newport-Bermuda race over the years (they have a well deserved exemption to the SI rules). Most recently, "Actaea" won the St. David's Lighthouse division in 2014.
Ocean Navigator had a good article about stability index vs. capsize length, and uses the B40 as an example of how the formula doesn't really give a fair assessment of the seaworthiness of beamy, shoal draft sailboats:
https://www.oceannavigator.com/stability/
"Actaea" lovely as she is, is more of a "Turbo B-40" with a ballast shoe on her keel, carbon spars and I think she has the Mark 3 Sloop Main mast instead of the Yawl Main which was a wee bit shorter. The Coen's have raced and cruised her vigorously throughout the Chesapeake.Not quite true. Many Hinckley B40's have participated in the Newport-Bermuda race over the years (they have a well deserved exemption to the SI rules). Most recently, "Actaea" won the St. David's Lighthouse division in 2014.
As a future prospective entrant with B-40 #24; where can I find the tests & calculations to figure out what modifications I would need to do to qualify ?Every individual boat goes through floatation measurement, including small-angle inclination and freeboards to datum points to calculate displacement and righting moment. VCG and other hydrostatic parameters are calculated by integrating floatation, inclination, and hull lines to yield the ORR SI.
You can consult with ORA, the owners of the ORR rule but I am sure that you will need a full measurement to qualify.As a future prospective entrant with B-40 #24; where can I find the tests & calculations to figure out what modifications I would need to do to qualify ?
Anything that floats is expensive. And anything cool that floats is even more expensive, but it’s still cool. Pragmatic though they may be, Beneteaus seem like such a boring solution. They are nice and new when new, but for 150k you get something about as appealing as a gently used, never detailed, 10 year old Toyota Corolla. It’s practical, it will never do you wrong, but It hardly pulls the heart stings. Wouldn’t you rather have the B40? It’s at least got some charm… and it draws a foot less, looks amazing, and isn’t THAT much slower. The full keel is probably preferable on a nasty day in the gulf stream also.Cristoforo said:There is nothing cheap about owning an older Swan. And yes there are better choices Fla daysails and Bahamas. Also shorthanding a 46-47-48 is more than a handful for most couples. Sounds like you are in Beneteau territory.
I have a hard time getting excited about these for some reason. Every time I see a Hood designed boat that ticks all the boxes, it’s 250k. A 75k B40 is just as much a worn warship as a 50k Bristol, but at 150k the B40’s are as immaculate as a 250k little harbor. Maybe I just haven’t found the right one?Hood 38? (Bristol, Wauquiez, Little Harbor)
Actually the Scotch Tape to hold it all in place looks rather cheap.That looks expensive.
