seeker321
Diving in here on the battery debate....
Imnsho, LiFePO4 is, by far, the most rational choice for storing energy. I've been running a 720Ah Genesun pack now for almost four years. I say that with one of my packs hard down -- so only have 360Ah useable at the moment. Why one of the packs is down isn't fully determined yet, but I do know that one of my cells was spewing yellow powder. So guessing I need a coupe or more replacement cells.
I'm not stressing because the (excellent) Genasun BMS has long ago cut this pack out from both charging and discharging.
Warranty/support? What's to warranty? It's no different, really, than 6-volt golf cart batteries, 'cept the LiFePO4 cells are 1/3 the wright -- and, therefore, 1/3 the shipping cost to get replacements.
Probably the only REAL hassle is that I'm in Guam, and the bloody USPS refuses to ship Lithium batteries, so will have to use UPS or FedEx to ship replacements at 3x the price <grrrr>
So, why LFP -- for ANY boat? Weight. The ONLY place for lead (at least on monohulls) is at the VERY bottom of the keel. Anywhere else, it's parasitic. I'm on a mid to high performance ocean catamaran (chris white Atlantic 55) -- and ANY excess weight is parasitic. The LFP program allows weight savings across a broad spectrum. First, obviously, is the actual weight of the batteries. But, that's the LEAST significant weight savings. Given that the LFPs can (theoretically) charge at somewhere between 2.5 and 3C -- 'till absolutely full -- I spend WAY less time burning hydrocarbons to charge. In my case, I have two x 270 amp alts -- so less than 1C charging capacity. When there's zero solar (rare), I MAY have to fire up the charging source every couple of days for about 45 minutes to an hour to keep the system topped up.... That means that I need to carry WAY less fuel -- and this saves WAY more weight than the actual batteries!
I'll NEVER go back to lead. I'll be replacing my starting batteries next -- and add in the stock alternators to the above 270s and echo charge the the start batteries off the house. Even less running time for the engines
By the way, I live aboard full time. In VERY remote places. No second thoughts about this technology.
It's simply the best choice.
Oh, lastly, economics. I don't know if I'll get 3,000 or 5,000 cycles -- or perhaps even more. I DO know that as I get closer to the end of this limit, I'll still have LOTS of capacity left Nd -- in the same time frame would likely be on my third or fourth set of AGM batteries -- so, are LFPs REALLY that much more expensive?
