BalticBandit
- 36
Well as the IC testimony here indicates, hull drag does vary with attitude (and I'd tend to agree)I cannot see extra speed (with my emphasis) at all. If you make the assumption that hull drag doesn't vary much with attitude and (its only a medium sized assumption since we know that induced drag must be tiny in proportion to total induced, wetted surface drag is identical and wave drag must be very very similar) then if the foils are at the optimum angle to the wind in both boats, and the sails are at the optimum angle to the wind in both boats then all the dynamics are essentially the same. So how can the behaviour in the lulls be significantly different? In both boats the power available will decrease by the same amount, the heeling force will change by the same amount etc etc etc. I agree that in the gybing board boat the angle of the centre line is always nose down by the gybe angle of the board, but what I don't see is why that should make a blind bit of difference to anything other than the jib/main relationship. Which goes right back to my original proposition that the jib/main relationship, which we all know to be crucial to the upwind tuning, is the only factor that appears to change enough to have a significant effect.From a "normal boat" next to you, you would be "nose down" on them but tracking the same CMG - and you would have a touch more speed. And in the Lulls you would maintain point when they have to "nose down".
And that is EXACTLY what you see when you sail a non-gyber next to a gyber.
and yes, once in equilibrium the net lateral forces are zero. But the reason there is leeway is that the initial lateral forces are greater to leeward.
But I really don't understand this
Huh? Again, I am so confused by the terms that I cannot sort this. Normally since the goal is to go to weather, "negative" would be "away from" going to weather. so it sees completely contrary to every notion. And what is "weather force"?Disregarding gybers, for the boat to move to weather, the foil would have to be at a negative AOA, hence generating negative lift, so where on earth does the weather force come from?
