A
Amati
Yup yup that's the one...Ooh - I remember that paper - damn if I can't remember the title. I vaguely remember it being around circa 1995...Paul,When Hollom talks about Viscous forces dominating gravitational forces, you don't suppose that he means that the fin's low pressure reaches up around the hull to the gravity interface? I just spent an hour looking for a hydrodynamics paper on that very thing and of course I can't find it.
I'm sure I've read a similar article somwhere in the distant past. I think it was to do with why elliptical keels should be narrower at the root with max chord lower down the keel. As Andrew says, I can understand this with keels that are exposed to the free surface due to heeling, but not with a wide hull sailed flat.
Of course at high speeds the i14 is planing and the centreboard may well be exposed more to the free surface. But with the planing hull half out of the water it will be even less effective at providing lateral resistance, so the argument still doesn't stand up.
Mal.
But it was more than just the exposure to the free surface as I recollect. It also had to do with reducing spanwise migration of surface induced aerated water if I recollect...
My point (yes, I believe I had one :lol: ) is that too much aoa over a certain Reynolds Number regime (or maybe even speed?) excacerbated the effect the article above deals with, which might be why under 12K works for a gyber, but over 12 induces it (maybe ventilation of some sort?)? How much leeway resistance to you need off the wind anyway?
Just my imagination, or is the chine crowd happier with gybers than the non chines folk? If you think about it, if that's true, then I had it backwards (), and the more the hull resists leeway, the more a gyber is an advantage. So D.H. may have a point. (I love his stuff, but sometimes he riffs like Mr. Greenspan used to.)
Mr. Maas- you have chines, no?
Kind of makes me wonder about no chine hulls and gybers under 12K. Are Int 14 chines above the water enough over 12K so the hull essentially lifts up enough and becomes essentially a roundish no chine hull on plane, and then develop more leeway so the gyber becomes aoa overkill?
It seems to my eye that Paul usually puts his chines on the high side (?)- care to comment, Irrational 14er?
Paul
