Black walnut toe rails?
Sea_Squirrel
11
Appleton, WI
Greetings! I’ve got a project boat (Dolphin 24) that needs all of the toe rail replaced. I also happen to have an abundance of black walnut on hand… I’m wondering if anyone has experience with utilizing black walnut for deck applications, can I varnish this, can I use teak oil, is this a viable option?
Thanks!
slug zitski
1,197
worldwide
Thanks!
Walnut is an excellent boatbuilding wood
it’s defect is that because the trees are short and stout you have a difficult time finding clear long boards
Also consider iroko , mahogany , sepelie …quarter sawn
ask your timber supplier for suggestions
if possible use bronze fasteners …stainless stains the wood if it gets wet
Rasputin22
Rasputin22
13,894
3,453
A straight trunk of good quality black walnut that would make nice stock for toerails would probably be worth far more as a bole for veneering.
I couldn't tell ya the providence, but Black Walnut is bad luck on a boat.
Locust would be a good choice if you can find. I don't think there's a commercial market, so you need to find a small mill that has some that was "cut and stickered out back" long enough to have air dried.
Iroko is a commodity and is available as deck planks. I haven't worked with it much but I would do some research and destructive testing before using the terms "bend" and "scarf" in the same neighborhood. And wear a dust mask when working with tropical mystery woods.
SimonGH
88
Westbrook CT
I just did a home deck in Cumaru (Brazilian teak). Aside from being rock hard and very dense, I was able to get 18' clear boards. It seems like it would do well on a boat?
slug zitski
1,197
worldwide
synthetic will work
your choice
machining a toe rail is a big job that requires a workshop, bench and floor tools
that synthetic comes in a coil
much time saved
Sea_Squirrel
11
Appleton, WI
Thanks for all of the advice and ideas folks! I’d really like to keep the wood toe rails if possible, I know they’ll be more work but I think the reward is so worth it! I’ll have to do some pondering on this.. I’ve got all winter 😅
Grrr...
▰▰▰▰▰▰▰▰▰▰ 100%
9,980
2,452
Detroit
In that case, mahogoney. That's what I used for my rub rail, with a stainless steel cap to protect it from steel pilings. It's generally one of the easier to find woods.
