Black Jack
In his book, Thoughts, Tips, Techniques and Tactics for Singlehanded Sailing by Andrew Evans (aka Foolish) had some interesting thoughts on picking the right boat design and getting it set up correctly.
Many years ago when I returned to sailing and wanted to purchase a boat to solo/shorthand race I took a bunch from his short paragraphs on the subject recognizing that most of it was for an audience geared for those planning for the larger venue short handed ocean regattas. Most of us who often sail singled handed will only do (if we are fortunate) a small handful of long distance races leaving us to take the best of his advice to fit most of our needs. Interesting Evans opens his thoughts with the Cal20, Black Feathers*, proving anyone can solo sail anything if they are driven or prepared.
Evans wrote:
"When searching for a boat, the singlehander has a terrific advantage over the crewed boat owner. It seems that the most modern boats, those built within the past five years and thus the most expensive, are the least suitable for singlehanding. Older fiberglass boats, built twenty to thirty years ago, by their nature have the design features that are best suited to singlehanding."
The key features to seek out are:
1. Helm: Tiller rather than a wheel.
2. Cockpit: Small rather than large. The singlehander must be able to control all of the major lines while at the tiller, even if this means stretching forward with the tiller between his knees.
3. Mast: Strong and secure. When things go wrong, a singlehander will put far more stress on the mast than a crewed boat.
4. A single backstay without running backstays.
5. Below deck: Simplicity is best.
* Black Feathers: A Pocket Racer Sails the Singlehanded TransPac, by Robert and Jeanne Crawford, iUniverse, Inc., New York. ISBN 978-1-4401-9196-1.
Crawford lists the advantages and disadvantages of small boats:
CRAWFORD'S STATED ADVANTAGES OF USING A SMALLER/OLDER BOAT (JOHN VIGOR'S ABSTRACT)
► Cost, of course. Everything to do with small boats costs less than everything to do with big boats.
► Maintenance is easier and cheaper.
► You can more easily handle sails, winches, spinnaker poles, anchors, etc.
► Smaller spinnakers make dealing with snafus a lot less traumatic.
► Boat handling under normal conditions is easier and more forgiving because the boat is smaller and lighter.
► Small boats are more responsive and more maneuverable in confined spaces.
► Small boats can be rowed, paddled, or sculled.
► In a singlehanded race, the skipper of a small boat has a better chance of sailing a boat to its potential, thus improving his chances of winning on handicap.
► Smaller boats are less intimidating and easier to understand.
► Because smaller boats respond more quickly to change, you can more readily learn better sailing techniques.
► Because they’re less expensive to start with, you can experiment with gear changes that make holes everywhere, without destroying the value of an expensive boat.
► You have the feeling of being more at one with the water you’re sailing in.
► Because small boats generate small forces, breakage of equipment is not so common.
► If your boat develops a leak, it’s easier to trace and fix in a small boat that has fewer areas of the hull inaccessible.
► You can’t hoard too much heavy “stuff” on a small boat because there’s nowhere to put it.
► Emergency repairs to spars and rudders are more manageable. (Crawford himself had to ship a spare rudder at sea.)
► Erecting a jury mast is much simpler on a small boat.
DISADVANTAGES
► Small boats give you a rougher ride in heavy weather.
► You may have to beef up a small day-sailer for ocean work.
► Small boats often lack headroom and interior space. They won’t offer luxuries such as a full galley with fridge, or a shower, or even a fixed head.
► They’re not as fast as larger boats — but, let’s face facts: even larger boats are slow, very slow, compared with other forms of transport.
Taking these considerations seriously, it brings up our own choices intentionally chosen for singlehanded sailing and mostly for short course, day long or weekend racing with a hope of some day doing something much longer. Keeping in that spirit would you care to share the following -
DISADVANTAGES
- What boat have you chosen?
- What attributes on her really work for you ?
- What would you like to change on her?
- What compromises have you accepted?
- What is your monthly or yearly budget to keep her going?
