Not sure it can be taken out of a converted e scow.
If it is converted is it still one-design?Not sure it can be taken out of a converted e scow.
Unless you are regularly in contention for your National championship I wouldn't worry too much about 80 pounds on a boat with a sailing weight of 1600 plus pounds. One missed shift will hurt more than the excess pounds.
I hear people say this all the time. Not sure that is the right way to look at it.Unless you are regularly in contention for your National championship I wouldn't worry too much about 80 pounds on a boat with a sailing weight of 1600 plus pounds. One missed shift will hurt more than the excess pounds.
There's an old saying: "Nothing makes your tactics look better than a fast boat."I hear people say this all the time. Not sure that is the right way to look at it.
If you are 80lbs over weight in a competitive one design you are going to be a tick slower. And on the first beat, that might be the difference between crossing someone or getting bounced the wrong way on the course. Now you cant get to that good shift. You can quickly find your self off the front row of the fleet, now you are in gas and the world just keeps getting more challenging. Or maybe on the run you cant hold that overlap at the bottom mar and now round outside in gas. So while your 80 lbs may have been a small fraction of a knot in speed, what it harms in terms of tactical options can be far greater.
I thought the boat was dry, but there is alot of places for water to hide in an e scow. Going to re-weigh it again. I agree the conversion should not had that much weight.That’s the equivalent weight of a couple of 5 gallon buckets of paint. That’s not a small amount on a one design Escow. I can’t imagine a repair job or assym launch port using that much material. Was the scale accurate and the boat completely empty and dry inside?
For your opti, 80 lbs is quite a bit more weight to ship around....................for the 100 footer - not so muchIf a one design boat is heavy, say 50-80lbs over weight, how much of a factor is that? Should you sail with a lighter crew to compensate? Thoughts?
