MaxHugen
I don't quite follow erdb's diagrams. In the second from left, the point at which Vertical force should be equal for both wings of a Y foil is when the foil is at 0° cant, ignoring leeway for the moment. That means the foil arm would be at a cant of 42°, not at 60°. (foil arm cant - 42 = foil cant)The more I read this, the more intuitive it feels.
Why would force on each side of the arm be equal?
Even without flap differential the inboard wing would load up more due to leeway increasing its AoA more than the outboard wing. But with flap differential you could produce the same loading difference but with less leeway.
Result is thay LR can ay around with different CoE heights without canting or can move foil can without having to change CoE height?
The thing that still has me confused is thay the upwind cant angles seem very high. I'm not sure they cant be achieved without the hull touching down or the foil surfacing. Os thay becuase the VPP was just left to keep getting faster VMG without limit on maximum cant?
As you mention, leeway will increase the AoA of the windward wing more than the leeward wing. An example of leeway calcs (thanks to @enigmatically2's equation) :
- Foil cant = 22°
- Foil AoA = 0°
- Foil anhedral = 16°
- Windward wing cant = 38°
- Leeward wing cant = 6°
- Leeway = 2°
- Windward wing AoA = 1.23°
- Leeward wing AoA = 0.21°
