terrafirma
It's almost a race that's all about foils. Certainly interesting on Dihedral with the foils. Interesting video on Dihedral here
Are you thinking something like below?With only 6 foils total across 2 boats for the whole campaign I'm not expecting to see a 2nd pair from teams at least until the 2nd boats & maybe not even then unless they fucked up in a big way with 1st set.
Thoughts on the legality of changing anhedral angle?
Doesn't seem to require the unmodified material to remain in the same 3D location, allows for alignment of unmodified area for comparison.
I think that would allow angle changes with minimal mass change via a little bit of filler around the joint if its been designed with that intent.
Why would you want to?not exactly on the point - but It is strange to see no one team use foiling chase boat - any thoughts ?
Exactly that yes.Are you thinking something like below?
i.e. depending on whether you are allowed to make the comparison on any arbitrarily small volume (A to A, and B to B) , or whether you have to make the comparison on a global volume (C to C), you can either have the change being the purple/blue, or the orange/green volumes and associate masses.
Do they define 'component'?
I suspect the C to C comparison is the intent, but maybe there's a loophole you have identified.
edit: duplicate image deleted
If a sailor on the boat fell overboard and was lucky enough to miss getting quartered by the foilsWhy would you want to?
Much more faster and smooth ride, than conventional chase boat.Why would you want to?
Then why aren’t ALL boats foiling?Much more faster and smooth ride, than conventional chase boat.
Same time will need 50% less fuel, which is not small number, counting there are more than one chase boat follwoing 110 % each AC75 + one spy boat.
I think the foils are connected with a lot more than a butt join + fillet. A foil wing is the entire wing, tip to tip, including the bulb but excluding the arm, flaps and foil systems. Changing from flat to anhedral is going to change a lot more mass than just the fillet.Are you thinking something like below?
Weight and cost mostly I imagine, not many people can afford carbon fibre honeycomb just to go fishing.Then why aren’t ALL boats foiling?
If the chase boats had foils it would be to reduce the power required to keep up with the foiling monos but then they they would not have enough power to perform their tugboat duties.not exactly on the point - but It is strange to see no one team use foiling chase boat - any thoughts ?
5.10 For components listed in Rule 5.1 that have a “Change allowance” mass percentage:Until the methodology for measuring the 20% of mass is known, and some realistic estimates for foil changes are available, it's fairly pointless to speculate.
Attn: @zlobkoWeight and cost mostly I imagine, not many people can afford carbon fibre honeycomb just to go fishing.
Freight is simply too heavy and for passengers it only makes sense if the distance and conditions are such that it results in more money.
A Mercury 400R running at 3,000 RPM uses 29.9 l/hr and at 5,000 RPM uses 69.8 l/hr. A full–foiling chase boat might theoretically keep the same engines and just throttle back to reduce fuel consumption (or shut down one engine and raise the leg) in the order of 120 l/hr.If the chase boats had foils it would be to reduce the power required to keep up with the foiling monos but then they they would not have enough power to perform their tugboat duties.
Certainly not a butt-join but at least some of the IACCs were setup with a joint socket setup designed to allow easy wing/angle changes & I'm thinking of something like that.I think the foils are connected with a lot more than a butt join + fillet. A foil wing is the entire wing, tip to tip, including the bulb but excluding the arm, flaps and foil systems. Changing from flat to anhedral is going to change a lot more mass than just the fillet.
Nice. Iges don't lie. So changes in space count.5.10 For components listed in Rule 5.1 that have a “Change allowance” mass percentage:
(a) When such a component is first declared according to Rule 5.5, the Competitor must declare to the
Measurement Committee:
(i) a component mass;
(ii) an IGES file of an exterior component shape; and
(iii) construction drawings showing the internal structure of the component.
(b) At all times when that component is installed on an AC75 Class Yacht with that yacht afloat:
(i) at least 80% of the mass of the component must match the original component; and
(ii) a common portion of at least 80% of the mass of the original component must remain un-
modified and must match all declared versions of the component.
(c) The portion of mass of a component that matches another version of that component is determined
by aligning the unmodified portion of the original and modified components and determining the
mass of all regions where the material substance remains unmodified and in the same place in both
(d) Material that has been replaced with identical or equivalent material only classifies as an unmodified
region where replacement was carried out as a repair permitted by Rule 5.12.
(e) When checking the shape of such a component against a declared IGES file, the Measurement Com-
mittee may make an allowance for unintended distortion of a component during manufacture.
(f) Competitors may declare a hypothetical “original component” which must comply with the relevant
rules for that component type, but is not required to be identical to the component when it is first
installed and afloat. In this case, the “original component” comprises those regions of the actual
component as-launched that match the hypothetical component, combined with the regions in the
hypothetical component that do not match the as-launched component and are presumed to have
been removed/modified to achieve the as-launched component. The component as first launched
must have corresponding declarations which must satisfy the permitted changes with respect to the
hypothetical “original component”.
(g) If the component when it is first installed and afloat does not comply with the relevant rules for that
component type, the Competitor must declare a hypothetical component that does comply with
those rules, in accordance with Rule 5.10 (f).
Clause c is the kicker
The Auckland Waiheke ferry "Manu Wai" was a hydro foil and it ran from 1964 to 1973. It was retired because of operational problems.A Mercury 400R running at 3,000 RPM uses 29.9 l/hr and at 5,000 RPM uses 69.8 l/hr. A full–foiling chase boat might theoretically keep the same engines and just throttle back to reduce fuel consumption (or shut down one engine and raise the leg) in the order of 120 l/hr.
I'm not going to guess how to get a standard outboard to operate on a full foiling boat. I expect they'd need an inboard with a drive that can be raised and lowered, or a jet.
Foiling might make it easier to operate a computer at speed.
