The teams aren't stupid. They will all go deep in light winds and have a timed run to the line. Keep their noses clean. Foiling to the line in the final 20 secs.The cats were dogs when off their foils the AC75's will be a lot worse.
Pre starts in anything under 15-20 knots will be a larf.
Crikey that will be a exciting spectacle.They will all go deep in light winds and have a timed run to the line. Keep their noses clean. Foiling to the line in the final 20 secs.
Go deep, get foiling. Then some interesting tactics. There were some very interesting starts in 8 kt in bda, and from all accounts these boats will be as adept in light air. Expect manoeuvres to be even more important in a windward start box.The teams aren't stupid. They will all go deep in light winds and have a timed run to the line. Keep their noses clean. Foiling to the line in the final 20 secs.
Unless you think the old flappy sails dial-ups were any more interesting...snore
Got any evidence.from all accounts these boats will be as adept in light air
So why bring it up?Well, that is correct.
Multiple guesstimates on here of 30kt in 8 on etnz first gen boat.Got any evidence.
Has nobody told you that the America’s Cup is won by the fastest boat around the course...It’s not ballroom dancing ?!? :blink:Must be a millennial thing.
Pre starts are were the opportunity to showcase tactics skills and seamanship.
Going deep and not engaging staying clean cause your foiler ain't foiling wow sounds as boring as Bermuda.
They won’t dial-up. They will keep movingCan't wait to see two lame ducks capsize in a dial up!
Hopefully they will experiment a bit in Cagliari.
People commit suicide too, so why not.They won’t dial-up. They will keep moving
Depends, doesn't it? If team A reckon they can get team B to capsize pre-start then they'll do whatever they can. Interesting that TNZ's design can be thought of as the most 'dangerous' in this regard - having less (or no) weight in the foils and not looking like a barge.They won’t dial-up. They will keep moving
They don’t have less weight in the foils. The AC75 gets its stability through being dynamic. Nobody is going to want to be dead in the water.Depends, doesn't it? If team A reckon they can get team B to capsize pre-start then they'll do whatever they can. Interesting that TNZ's design can be thought of as the most 'dangerous' in this regard - having less (or no) weight in the foils and not looking like a barge.
Bet'ya that BenHit and Spitbull will luff their ennemy until fall in the prestart.They won’t dial-up. They will keep moving
I thought they could have both foils down and that they would be quite stable that way.They don’t have less weight in the foils. The AC75 gets its stability through being dynamic. Nobody is going to want to be dead in the water.
Some of the foils have a conspicuous bulb on them. Containing, I suspect, lead. TNZ do not.I thought they could have both foils down and that they would be quite stable that way.
Might I suggest you avail yourself of the class rule mateSome of the foils have a conspicuous bulb on them. Containing, I suspect, lead. TNZ do not.
So what is in them?Might I suggest you avail yourself of the class rule mate![]()
