blackjenner
Could something like this eventually replace bottom paint?
Nope, but I have plans to. I'm going to try it on a few things, including my rudder which has no antifoul on it right now, to see how it works. I'm also going to spray the bottom of my inflatable. I should be doing both projects in mid-march so I'll let you know how it goes.Lance did you order it yet? It might be something I want to try, but going to be horrible to remove if it doesn't work
They are not marketing it as an anti fouling coating. I believe they intend it should be used above the waterline as anti corrosion protection. In addition, it has a very short useful life, when exposed to UV.From their web site it seems that they are marketing it as a marnine coating. Whatever that means.
so below the waterline (wet sailed ) (ultra ever dry) what would you expect the longevity to be based upon your experience with various coatings?They are not marketing it as an anti fouling coating. I believe they intend it should be used above the waterline as anti corrosion protection. In addition, it has a very short useful life, when exposed to UV.From their web site it seems that they are marketing it as a marnine coating. Whatever that means.
