I have been tracking down persistent leaks in my Farr 740 Sport, just about have them all fixed and every one has been because the PO apparently did not believe in bedding deck hardware. The LED bow lights are no exception, poor installation. In this case the PO drilled through the rub rail/flange and jammed the LED light through the hole sans any sealant. It is so tight that I will most likely destroy the light getting it out. Having searched the net for a replacement I have been unable to ID the manufacturer or the source of a replacement. Can anyone ID this light?
The mounting plate is about 3-3/8" long (85mm) and the lens diameter is about 1/2" (12mm).
thanks in advance,
mike
thanks in advance,
mike
