Brand new multi 23 - but the beams are cut
Multihauler
10
Yep, it's true.......
Last time I saw the boat, it appeared to have been sitting for awhile.
Cheers!!!
-MH
eric e
9
nz.akl
i can only think
it was a failed folding project.....
whatever
building new beams would solve the 23's
excessive dihedral angle
even nicely shaped ply box beams would do
ah bugger it
someone do a full seacart 'farrier top, water-stay bottom' job on it
Raz'r
5,468
De Nile
i can only think
whatever
ah bugger it
either way, I'd want an engineer to figure it out. The cut looks to be in an odd spot for strength, although perfect for trailering...
floater
Super Duper Anarchist
4,934
795
quivira regnum
i can only think
whatever
ah bugger it
both foldable and demountable beams - are full beams. At least all those I have seen.
The folding beam fastens to the deck.
The demountable beam is even longer, as it typically penetrates the hull into a female fitting.
So what was the vision of the man wielding the chain saw here? A sleeve can be built for a mast, so perhaps a plug and sleeve fitting was the notion...
sail(plane)
106
i can only think
whatever
ah bugger it
from the ad: " It includes design and plans for sliding floats."
seems like a failed sliding project? a sliding Multi23 doesn´t sound too attractive
you have to be really confident or crazy or both to cut THAT in a brand new multi...
eric e
9
nz.akl
sliding makes a lot of sense in that it would keep the float to beam connection intact
and possible would have changed this m23
from a 2-man assemble to a solo assemble
a worthy goal
sail(plane)
106
a worthy goal
I have the pre conceived idea that any sliding system will have some play and movement over the long run. Folding seems a more positive locking system in the sense of keeping rigidity and dimensions. For a boat like this, am I wrong? Are there proven sliding systems for this application?
eric e
9
nz.akl
i'd say you're right
that the current folding systems
are better than the current sliding systems
and the carved up beams
tend to support it was a brave experiment, for solo- setup?
that was ahead of its time design wise
i'm no expert but i would be surprised if there was sufficient hull and space
for a full farrier folding system that could be done solo
mad
a worthy goal
Only makes sense if the beams have been engineered and built with this in mind.
Otherwise, it just an idiot yet again cutting into highly loaded composites hoping/wishing it'll be alright.
FFS, people need to stop cutting shit apart when they have no idea about the loads and the materials they're built with.
sail(plane)
106
would be interesting if the brave owner gave some info on its thoughts when doing it. He does say there is a design and drawings. It might even help him sell it!
