Don't get hang up on the Libra example. I wrote it as I was suprised to see such a high SA/ballast for such a big boat. The Libra is a very extreme boat and not representative for sportsboats in general.
Even if comparing SA/ballast is not a one for one between different boats, I do think it tells a lot comparing boats of similar size. Sure, if you compare an RSK6, VX, and and Open 5.70, different dynamics comes into play when sailing upwind. Both the Open and the RSK6 hullshapes are designed to sail with some degree of heel, where the VX should be sailed more upright.
What purpose does the ballast have on a sport boat. I can see three going from less ballast to more.
1, Make the boat selfright
2, Make the boat easier to sail
3, Contribute to the RM when sailing
#1 is the bare minimum. When knocked down and the mast top is in the water, the RM from the keel must be bigger than the negative RM from the rigg. The negative RM from the rigg should be proprtional to the SA, not linier, less than square, probably somwhere in between.
What is interesting with the VX is that it seems to be designed to fulfill #1 but no more. I think this is quite rare for sportsboat, and the only other boat in this sie (around 20') to have similar objective is the Shaw 650, especially in its first configuration with a 70kg ballast (if I remember right.
So in summary, in the 20' size, only the VX and the Shaw 650 seems to be designed to fulfill criteria #1 but no more where all other boats have higher ballast and to some degree contribute to criteria #2 and #3.
I'm actually from now ignoring what Gybeset writes. He tends to look at a post and rather to try to understand what it is saying just try to find something that he can disagree to and put all is efforts into that. Highly unproductive. He fits the steriotype "grumpy old men" very well. People who have tried hard but failed to achieve any level of success, hence they got grumpy. Best to leave them by themselves.
