British IRC Nationals
King didn't fit the specified props hence the issue, Blondie's has been upgraded and no doubt so will the others
Just as a matter of detail, a King rep did indeed fit the prop on Argie bargie. It was re-fitted after the originally supplied anode showed significant signs of degradation after just 4 days in the water and also had to be replaced. King are supplying new props.
HamishMacdonald
Beken were there, but you can only see really small proofs on their site - unfortunately they've got a really good sequence of us going into a gybeset but then having to pull out halfway through cos the back of the boat hit the mark!
The official photog's site is down at the moment.
If Mills is 0 and Ker 1, then Corby must be 2 because his Rosie design won the entire event.
Good result for a bunch of Howth boys with the boatbuilder calling the tacticks and an annual budget that wouldn't last a weekend on some of the new boats.
:ph34r: :ph34r: :ph34r: I agree, well done to David Nixon and the team....... its also great to see an consistant owner like Roy Dixon getting just rewards
Thiepval
Here is Baby Doll again, doing her "Corby Chearleader" bit.....
Is this the first reference to John Corby in this thread?
Baby Doll
I thought we were meant to talk about sailing on sailing anarchy! Why do you have such a chip on your shoulder?
Im guessing: 1) You are a failed yacht designer.
2) You are one of John Corby's ex girlfriends
3) You have an issue with the fact that you are never going to be able to afford a nice yacht of your own so you have to insult everyone elses.
4) You got kicked off a Corby yacht when they wanted to better and you were too crap.
5) You are a guy and you have a secret crush which he's turned down.
I dont know what your issue is, but its a major one, and im suggesting it could be caused by one of the points above.
If you ever want to talk just drop me an email, we could maybe help you get over it.
For now however, chill out and stop being nasty about me on more than one thread because trust me, girls can be bitchy!
Thiepval
1) Negative
2) Negative - no no definately not.
3) Negative
4) Negative - never sailed on a Corby boat actually.
5) Negative, but it is quite funny.....
No problem, have it your own way. I am now off to my chilling zone!
