00seven
James "Grumpy" Bond
It' still there... (my downvote to you is for demo purposes only)Why did they take away the down-vote button? Badly needed here…
Ist alle the wayr to the lefteIt' still there... (my downvote to you is for demo purposes only)
The issue is measurement integrity (and trust), not competitor integrity.
Whatever the rule says.This.
Begs the question, what's an appropriate tolerance to apply to the measurement numbers?
2019 is the rig, foil and bulb change, so ignore anything before that first Celestial cert.I found the 2012 ORCi cert for the boats original inshore configuration when it was racinbg as Audi All Four One (according to Scanas)
Audi (2012)- Displacement 7,152 kg https://data.orc.org/public/WPub.dll/CC/30907
Could not find a rating for any of the other names of the boat until Celestial.
Celestial (2019) Displacement 6,953kg https://data.orc.org/public/WPub.dll/CC/122848
Celestial (2020) Displacement 6,986kg https://data.orc.org/public/WPub.dll/CC/133724
Celestial (April 2022) Displacement 6,988 kg https://data.orc.org/public/WPub.dll/CC/163121
Celestial (December 2022) Displacement 6,922 kg https://data.orc.org/public/WPub.dll/CC/175685
Discuss......
In the case of IRC and rating reviews:
9.7 Where the TCC is reviewed, either as a result of a rating review or a protest, and found
to be more than 0.005 greater than before, the contested certificate is invalid from the
date of issue.
9.8 In either case where the TCC is reviewed, the certificate becomes invalid if any remeasurement which increases the boat’s rating differs from the measurement shown on
the certificate by more than 1% of: LH, LWP, Hull Beam, Draft, P, E, J, FL, STL, SPL,
HLUmax, MUW, MTW, MHW (see Appendix A); by more than 2% of SPA, HSA or FSA; by
more than 5% of y, x or h; or by 5% in respect of weights; or if specific detail is clearly in
error.
I don't know why numbers changed 2019 to 2020 to April 2022 - when the measurement and flotation dates remained fixed at 28/11/2019 on all three, and there's no notes on the certs. about adding more weight through equipment changes.
Its the 6988 -> 6922 change which is the important one.
no - that's the "~200kg removed from the bulb, but displacement on the cert didn't really change much" point.Load cell tolerance...
Discuss......
(6988 - 200) != 6922 +- tolerance
agreed -- which is less than the limit on anything actionable after a review, however the IRC measurement manual (https://ircrating.org/wp-content/uploads/2022/11/IRC-Measurement-Manual-2023.pdf) says the load cell must be +-0.2% of full scale with a better than 10kg resolution.134kg.
Less than 2%..
""I felt we were rated very high for a 2011 boat, and although 12 years old since build, we had one of the highest ratings. So we weighed the boat, and discovered that it was heavier than thought. We went to J/V and they said, well, you should take a couple of hundred kilos out of the bulb."
You're missing that the certificate weight is not the same as the boat weight on a load cell and year-on-year ORC/IMS/ORCi varies allowances/assumptions with regards to kit on board and other calculations to go from measured weight to rated weight.Someone help me out here.
The special weighing he was talking about supposedly happened in Dec 2022. But the boat has been weighed as part of routine several times before that, including early Dec 2022 with 5 other boats.
WTF am I missing?
That does not explain ...You're missing that the certificate weight is not the same as the boat weight on a load cell and year-on-year ORC/IMS/ORCi varies allowances/assumptions with regards to kit on board and other calculations to go from measured weight to rated weight.
It is possible that for the same hull offset file and the same overhang measurements and the same flotation (draught) measurement the formulae get a slightly different calculated displacement.
A 1% tolerance on draft? Are they eye balling these measurements?Whatever the rule says.
date of issue.
error.
Without knowledge of the exact situation:That does not explain ...
When it had been weighed several times recently.
IRC penalises boats for being light and also penalises boats for having heavy bulbs. If you're certificate says you're 69xxkg but your boat is actually 71xxkg then you're carrying a penalty in your rating that you don't need. If you had the boat reweighed and discovered this you could rerate the boat at the higher displacement and shave a bit off your handicap. Alternatively, you could make your boat weigh 69xxkg by removing weight from the bulb which would also shave some points off your handicap. If you were trying to win a downwind race the latter is helpful.I am not asking about the small differences in mass, I'm asking why they claim it was 'heavier than thought' was the problem and that 230 kg off the bulb was the solution.
WTF am I missing?
